Jul 16th, 2024, 5:36am
parasitic  in Assura RCX.. (Read 985 times)
deepak
Jul 30th, 2009, 4:07am
for the same circuit extraction was done in calibre.... now wehn I did same extraction wiht assura,it is showing large parasitic resistance. for few nets.........
any idea????
rl1482 ( dvss12\#15991 dvss12\#15386 ) resistor r=999999995904.0000
rl1492 ( dvss12\#15305 dvss12\#16867 ) resistor r=999999995904.0000
Re: parasitic  in Assura RCX..
Reply #1 - Jul 30th, 2009, 5:29am
You need to press the "don't give me the wrong answer" button on the form.
OK, I'm being facetious. Realistically this is either that there's a bug in the version you're using (I've not seen this before though), or more likely there is something wrong with the technology files.
Since you can't give all the information in a public forum like this, I'd suggest you contact Cadence Customer Support (via sourcelink.cadence.com say) and they can help you look into why the problem occurs.
deepak
Reply #2 - Aug 2nd, 2009, 9:24pm
You need to press the "don't give me the wrong answer" button on the form..??
I cant find any such buton...... in the extraction...   where exactly is it??....
by d way I am using assure verification tool....5141..cadence....
Reply #3 - Aug 15th, 2009, 7:03am
The button you're looking for is just next to the "I was only kidding" button.
