You need to press the "don't give me the wrong answer" button on the form.
OK, I'm being facetious. Realistically this is either that there's a bug in the version you're using (I've not seen this before though), or more likely there is something wrong with the technology files.
Since you can't give all the information in a public forum like this, I'd suggest you contact Cadence Customer Support (via sourcelink.cadence.com say) and they can help you look into why the problem occurs.
