May 6th, 2024, 3:44am
questions about noise figure for mixers (Read 4530 times)
eecs4ever
Nov 19th, 2009, 4:05pm
Hi everyone,
I have a few questions about the noise figure for a mixer. How is the noise figure for a mixer defined? If the mixer has a given conversion gain and noise figure, how much noise is added at the output? Does the noise figure take noise folding into account? Since the mixer has 2 inputs, does it make certain assumptions about these inputs?
Definition of Noise Figure:
http://en.wikipedia.org/wiki/Noise_figure
Thank you.
Re: questions about noise figure for mixers
Reply #1 - Nov 20th, 2009, 4:13am
eecs4ever wrote on Nov 19th, 2009, 4:05pm:
Your questions are too vague, so I can't understand meaning of your questions.
Yes.
What do you mean by 2 inputs ?
You mean USB and LSB for RF ?
Or simply you mean RF and LO inputs ?
http://edocs.soco.agilent.com/display/ads2009/Harmonic+Balance+for+Mixers
http://www.designers-guide.org/Forum/YaBB.pl?num=1239925339
http://www.designers-guide.org/Forum/YaBB.pl?num=1234783833
« Last Edit: Nov 21st, 2009, 2:39am by pancho_hideboo »
eecs4ever
Reply #2 - Nov 20th, 2009, 10:28am
Hi Pancho_hideboo,
Thanks for responding. I'll try to clarify my questions. The definition for noise figure is SNRin/SNRout assuming an input noise floor of kTB (typically -174dBc/Hz). For an amplifier, the output noise floor is raised by the amplifier gain plus the noise figure in dB. Does this hold for a mixer as well? I was wondering if the mixing operation or noise folding makes it more complicated for a mixer than for an amplifier, or if I can assume that the noise floor at the mixer output is raised in the same way as for an amplifier.
For the two inputs, I meant the RF and LO. Is the noise folding different if the RF and LO are the same frequency and we are mixing down to baseband as oppose to an IF? If these are different, is there a separate noise figure for each case? Also are we assuming that the input noise floor is only applied at the RF signal and the LO signal is pure when taking the noise figure of the mixer?
Thanks again.
Reply #3 - Nov 20th, 2009, 11:07pm
eecs4ever wrote on Nov 20th, 2009, 10:28am:
Yes, if B=1Hz although you have typo.
But you have to consider "Spurious Response Frequencies" for RF inputs.
For example, Half-IF, SSB(USB, LSB) and DSB.
Again see http://www.designers-guide.org/Forum/YaBB.pl?num=1239925339
Both for zero-IF and non-zero-IF, they are different.
Generally we don't define NF for LO input.
Noise effect from LO is also included in NF for RF Port. Here noise folding from LO is also included.
Consider Numerator and Denominator of NF definition.
Most important things of NF for Mixer is that there are many RF frequencies which yield same IF frequency.
These frequencies are called as "Image Frequencies" or "Spurious Response Frequencies".
Again see http://edocs.soco.agilent.com/display/ads2009/Harmonic+Balance+for+Mixers
« Last Edit: Nov 21st, 2009, 3:26am by pancho_hideboo »
