May 21st, 2024, 11:43am
Pages: 1 2
design example for gm/Id methodology (Read 2864 times)
ipyd
Dec 30th, 2009, 2:41am
hi all..
i have read that gm/Id methodology is useful for designing CMOS analog circuit in every operating region. but i am still confused when trying to design simple telescopic differential op-amp.
i have known how to plot every graph that is used in this methodology, for instance gm/Id vs. Id/(W/L) graph ..
but i am confused about how to use that graph to find size of W and L of transistors..
i have googled for some literatures or tutorial that explain about how to design using this methodology step-by-step.. unfortunately, i haven't found any yet..
does anyone have it?
i think i should read more..
thank you
chmf
Re: design example for gm/Id methodology
Reply #1 - Dec 30th, 2009, 5:16pm
You can refer EE240 project.
I'm studying gm/id methodology, but do not know how to build the test bench in order to simulate open-loop gain Vs vod, AC loop gain @Vod=0v and AC loop gain @Vod=Vod,max.
Hope someone can give some helps.
Mayank
Reply #2 - Dec 30th, 2009, 8:44pm
Hi guys,
            Go through Borris Murmann's EE 240 course..[esp. lec 3 4 5]....It explains gm/id quite extensively.....It would surely help.
@ chmf : I mailed you on gmail....Did that help ??
regards,
Mayank.
ipyd
Reply #3 - Dec 31st, 2009, 1:16am
Mayank wrote on Dec 30th, 2009, 8:44pm:
Didn't find any Murmann's EE240, but his EE214 instead.
Thanks anyway..
Mayank
Reply #4 - Dec 31st, 2009, 7:29am
Ohhh My bad,
                    It's EE214 indeed....Advanced Analog Integrated Circuit Design.   https://ccnet.stanford.edu/cgi-bin/course.cgi?cc=ee214&action=main_page
regards,
Mayank.
Reply #5 - Jan 1st, 2010, 6:57pm
EECS240 would be the number at Berkeley, where he used to teach.
RFICDUDE
Reply #6 - Jan 2nd, 2010, 7:38pm
There is a good new book dedicated to the subject of CMOS design  by length and inversion coefficient.
I highly recommend it as a reference, and it has a couple of OTA examples in the later chapters of the book.
Tradeoffs and Optimization in Analog CMOS Design, John Wiley and Sons Ltd., ISBN 978-0-470-03136-0, June 2008.
He also has a website where you can download some Excel based design example worksheets used in the book.
nobody
Reply #7 - Jan 2nd, 2010, 9:56pm
I read that book and the author uses EKV model as examples.
ipyd
Reply #8 - Jan 3rd, 2010, 3:48pm
it's David Binkley's book, isn't it?
AnalogDE
Reply #9 - Jan 4th, 2010, 7:21pm
Here's a gm/id book I've been looking at getting on amazon, it looks like it's finally out..
Has anyone obtained a copy?
RFICDUDE
Reply #10 - Jan 5th, 2010, 3:46am
Yes, it is Dr. David Binkley's (UNC Charlotte) book.
The book is a comprehensive presentation on how CMOS performance parameters are related to Length and inversion coefficient with single ended and full differential OTA design examples.
However, it is not quick explanation or lecture on how to design an OTA using gm/Id. But the material could be adapted into any analog CMOS design course.
AnalogDE
Reply #11 - Jan 7th, 2010, 5:59pm
The link to the book I was talking about above is here:
http://www.amazon.com/Methodology-sizing-low-voltage-analog-Circuits/dp/03874710...
ipyd
Reply #12 - Jan 12th, 2010, 9:09am
i am confused how to setup simulation to get gm/ID vs ID/W graph.
in Mr.Murmann's lecture notes, he use single nmos which its drain and gate isn't connected each other. he uses about VDD/2 for VDS voltage and runs dc simulation for variable VGS voltage. FYI, I found different result for different VDS voltage.
On the other hand, in Ashutosh Tiwari's lecture notes, he also runs dc simulation for variable VGS voltage but with drain terminal connects to gate terminal, which ensure the device remains in saturation region.
which one is correct?
**please refer to : http://discovery.bits-pilani.ac.in/discipline/eee/agupta/microelectronic-circuit... for Ashutosh Tiwari's lecture notes.
Mayank
Reply #13 - Jan 12th, 2010, 8:54pm
     Both methods are approximation to ideal situation....
Obviously, you will find different results for different vds voltages...MOS current has a loose dependence on vds too....But until the vds is too low, the change in the figures of merit of a MOS is very less.
If you want such accurate matching, sweep both VGS and  VDS voltages and generate data for different vgs / vds permutations & you are good to go.
Mayank.
analogrf
Reply #14 - Jan 15th, 2010, 5:51pm
Hi Mayank,
I had a very long discussion at edaboard, about getting the correct gm/id VS id/(W/L) curves. Problem is, ultimately i would not get the correct curves. Could u suggest a reason if you have tried this before ?
http://www.edaboard.com/ftopic377596.html
Pages: 1 2
