May 2nd, 2024, 12:58pm
Pages: 1 2
PRBS pattern for eye diagram USB FS driver... (Read 392 times)
somisetty
Jan 20th, 2010, 11:37pm
hi,
i wanted to generate eye diagram for USB FullSpeed Driver to measure jitter.Would any one suggest me,the PRBS pattern,need to use for generating eye diagram?
pattern means how may minimum bits required to get any eye pattern...bit time etc...
raja.cedt
Re: PRBS pattern for eye diagram USB FS driver...
Reply #1 - Jan 21st, 2010, 7:30am
hi,
   i didn't understand your question, can you reframe it. I mean bit time is the one for which you design enitre transiver and give some junk prbs and get the EYE.
RAjasekhar.
somisetty
Reply #2 - Jan 22nd, 2010, 2:57am
Thanks for the reply..
I wanted to generate any eye diagram for USB Full Speed Driver.For  that i need a prbs.To generate a prbs,i got a perl script which requires the bit-time as input.
USB protocol defines USB FS mode should have 12Mb/s data rate.I calculated the bit time as 83.33nsec.Iam not sure abt  the bit time.can anyone clarify the bit-time?
Reply #3 - Jan 22nd, 2010, 3:12am
somisetty wrote on Jan 22nd, 2010, 2:57am:
Correct.
See http://www.designers-guide.org/Forum/YaBB.pl?num=1234925581/5#5
somisetty
Reply #4 - Jan 25th, 2010, 12:54am
Thanks for the reply...
I have given USB Full Speed Drivers a PRBS with bit time of 83n and 127bits. As USB Io is a differential output,the out pins shown in the image are DP_OUT ans DM_OUT.
when i generated the Eye diagram for 2 output pins separately with Time base as 83nsec and got the below eye...As you can see the eye is not complete,can any one let me know whats wrong with the simulation ...
Thanks again...
Reply #5 - Jan 25th, 2010, 1:03am
somisetty wrote on Jan 25th, 2010, 12:54am:
I think you have some mistakes in using function for eyediagram.
What tool do you use for post processing ?
What do you mean by "fs_dp" and "fs_dm" ?
somisetty
Reply #6 - Jan 25th, 2010, 1:08am
Iam using the tool CosmosScope by Synopsys...
fs_dm and fs_dp are input pins of the drivers and dp_out and dm_out are the outputs of the driver.
Reply #7 - Jan 25th, 2010, 1:10am
Upload your simulation data as  tr0, fsdb or psf format.
If you upload your simulation data, I can verify eyediagram.
somisetty
Reply #8 - Jan 25th, 2010, 2:04am
Thanks for the help...
pls find the file... "prbs.tr0" in prbs.rar
Reply #9 - Jan 26th, 2010, 1:39am
somisetty wrote on Jan 25th, 2010, 2:04am:
As I expected, there is no issue related to design in your post at all.
Your question is no more than easy usage of very specific vendor's tool.
Please post such questions to Simulator's Board not to Design's Board.
I verified your data("prbs.tr0") by Agilent ADS Post Processing Environment.
I found that a bit rate of your PRBS is 1/83nsec= 12.0482Mbps not 12.0Mbps.
Attached figure is conventional plot from your data("prbs.tr0").
Reply #10 - Jan 26th, 2010, 1:50am
Attached figure is an eyediagram for "fs_dp".
Reply #11 - Jan 26th, 2010, 1:51am
Attached figure is an eyediagram for "fs_dp_out".
Reply #12 - Jan 26th, 2010, 1:55am
See arguments of function of eye() in attached figure, although this is a function in Agilent ADS Post Processing Environment.
Here I set 1/83nsec as Bit Rate(=Symbol Rate).
Arguments of function for eyediagram are very simlar, even if you use CosmosScope of Synopsys.
Reply #13 - Jan 26th, 2010, 2:00am
Of course, I can plot an eyediagram using CosmosScope.
Show me your settings for eyediagram in CosmosScope.
Attached figure is my result.
Reply #14 - Jan 26th, 2010, 2:03am
Attached figure is an eyediagram using another settings.
Pages: 1 2
