Oct 4th, 2026, 3:00am
Converting a VHDL code to VHDL-AMS for simulation in Analog Design Environment. (Read 5594 times)
pkd
India
May 31st, 2010, 1:46pm
I have a VHDL code which I have simulated in modelsim and also synthesized in Xilinx board. But Now I need to put that entire code (The top one has 3 sub-modules in VHDL) into analog design environment to test out the characteristics of the overall system with the other analog blocks.
This is the first time I am trying to simulate an HDL code in ADE, so have very little idea about the flow. So, I would appreciate a bit of hints on how should I go about it in terms of various tools flow. I am having IUS82 tool. I have read the Verilog AMS guide in this comunity and successfully simulated the components like Flip-flops, AND gates ADC etc, but I didn't find any example there where a chunk of VHDL code of considerable magnitude being compiled in VerilogAMS and incorporated in ADE.
I have attached the code for one of my modules as a sample.
Waiting desperately for some useful hints/insights/suggestions/guidance.   Smiley
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Re: Converting a VHDL code to VHDL-AMS for simulation in Analog Design Environment.
Reply #1 - Jul 5th, 2010, 6:58am
If you want to work the analog way: Import the VHDL code into your environment using File -> Import -> VHDL from the CIW. That will give you a library with the VHDL block. You can then instantiate the VHDL block in your schematic. If you have selected the proper connect rules (similar to Verilog-AMS or Verilog examples) you can run your simulation from either ADE or the Hierarchy Editor using the AMS plugin.
Marq
jerome_ams
Reply #2 - Oct 26th, 2010, 7:14am
Basically, there is no need to "convert" your VHDL code. As VHDL-AMS is a superset of VHDL, an VHDL-AMS simulator will simulate VHDL.
Just import your code (i.e. compile it) in the Cadence database.
Cheers,
Jerome
