Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jun 30
th
, 2025, 5:04pm
Home
Help
Search
Login
Register
PM to admin
Design Languages
VHDL-AMS
› Converting a VHDL code to VHDL-AMS for simulation in Analog Design Environment.
Previous topic
Next topic
Converting a VHDL code to VHDL-AMS for simulation in Analog Design Environment. (Read 5060 times)
pkd
India
May 31
st
, 2010, 2:46pm
I have a VHDL code which I have simulated in modelsim and also synthesized in Xilinx board. But Now I need to put that entire code (The top one has 3 sub-modules in VHDL) into analog design environment to test out the characteristics of the overall system with the other analog blocks.
This is the first time I am trying to simulate an HDL code in ADE, so have very little idea about the flow. So, I would appreciate a bit of hints on how should I go about it in terms of various tools flow. I am having IUS82 tool. I have read the Verilog AMS guide in this comunity and successfully simulated the components like Flip-flops, AND gates ADC etc, but I didn't find any example there where a chunk of VHDL code of considerable magnitude being compiled in VerilogAMS and incorporated in ADE.
I have attached the code for one of my modules as a sample.
Waiting desperately for some useful hints/insights/suggestions/guidance.
IP Logged
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Re: Converting a VHDL code to VHDL-AMS for simulation in Analog Design Environment.
Reply #1 -
Jul 5
th
, 2010, 7:58am
If you want to work the analog way: Import the VHDL code into your environment using File -> Import -> VHDL from the CIW. That will give you a library with the VHDL block. You can then instantiate the VHDL block in your schematic. If you have selected the proper connect rules (similar to Verilog-AMS or Verilog examples) you can run your simulation from either ADE or the Hierarchy Editor using the AMS plugin.
Marq
IP Logged
jerome_ams
Reply #2 -
Oct 26
th
, 2010, 8:14am
Basically, there is no need to "convert" your VHDL code. As VHDL-AMS is a superset of VHDL, an VHDL-AMS simulator will simulate VHDL.
Just import your code (i.e. compile it) in the Cadence database.
Cheers,
Jerome
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
»» VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2025
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
