Apr 28th, 2024, 11:13pm
Pages: 1 2
low noise regulator for rf vco (Read 10743 times)
mosman
china
Jun 25th, 2010, 8:45pm
usually most vco are powered by a analog linear regulator.
can vco be supplied by one digital linear regulator? it means the regulator is still linear regulator not switch-type, DCDC. but because it is digital, its output voltage will changed step by step, maybe the step is 10mv, 20mv,... . i dont know if this style was used in vco in any real product. will this worsen the important noise performance? anybody has such experience?
View Profile mosman   IP Logged
Re: low noise regulator for rf vco
Reply #1 - Jun 25th, 2010, 10:10pm
mosman wrote on Jun 25th, 2010, 8:45pm:
No, it does not make noise performance worse as far as it is static change.
Actually it is fairly common to adjust voltage of regulator at room temperature by such digital step adjustment.
In some cases, we aggressively increase output voltage of regulator at high temperature by such digital change.
Vice versa, we aggressively decrease output voltage of regulator at low temperature by such digital change.
« Last Edit: Jun 26th, 2010, 12:04am by pancho_hideboo »
mosman
china
Reply #2 - Jun 26th, 2010, 2:03am
pancho_hideboo wrote on Jun 25th, 2010, 10:10pm:
i also see your reply in edaborad. thanks.
yes, i am facing such issue. the regulator will decrease its output at high temperature. the noise will be introduced if analog control loop is used. so the digital method is used. to adjust output voltage this digital loop will run once chip work, not only at chip startup. when the digital loop sends bits to adjust supply, the supply of every block will change about, say step=50mv. my application engineer worry about this 50mv step, i also has no experience on this. they also do. you say "it is static change", but at adjusting moment, the supply will be chnged one step, 50mv. i dont very understand this impact on vco's phase noise.
Reply #3 - Jun 26th, 2010, 2:08am
mosman wrote on Jun 26th, 2010, 2:03am:
Why does it introduce noise ?
It affects spurious emission rather than phase noise.
It might be unlocked state during a very very very small time, although I don't think it will be unlocked state by such small voltage change.
Anyway it can make purity of PLL worse during very small time.
Is VCO is always active in your system ?
I include voltage change sequence during channel change in PLL synthesizer.
Here I also include VCO frequency calibration sequence in every channel change.
Whether these are possible or not is dependent on required channel change time.
Mayank
Reply #4 - Jun 27th, 2010, 9:14pm
Any Analog Circuit will introduce noise.
I think what Pancho was trying to ask, & me too, is that why will the Digitally Controlled Supply NOT introduce any noise ??
What do you mean by Digital Control ?
1 -- You are calibrating the Reference Voltage of the Regulator Loop digitally ??
Without an Analog Loop, How will you remove Power Supply Noise & High & Low Frequency ripples ??
Pancho is right, i guess such small change of supply would instantaneously but small frequency shift in the VCO o/p Freq. depending on your Kpushing Factor, causing PLL to be in an unlocked state for a v small time.
yes, VCO output, will show spurious components every time you change your calibration code. If your VCO response to the Supply variation is Overdamped, they will die out soon enough.
Mayank.
Reply #5 - Jun 28th, 2010, 7:07am
Mayank wrote on Jun 27th, 2010, 9:14pm:
I don't think so.
Simple digitally controled voltage by temperature never introduce any additional noise as far as its change is static.
Here this control is done without any feedback loop.
I think he assumes digital adjustment of feed back resistor ratio in linear regulator.
rfcooltools.com
Reply #6 - Jun 28th, 2010, 11:55am
Linear regulator considerations for a VCO will include:
1. device type
2. size of device
3. vds
4. bandwidth and gain of feedback loop
5. vco symetry (balanced plus and minus swing)
6. Noise of regulators reference voltage
http://rfcooltools.com
Mayank
Reply #7 - Jun 29th, 2010, 1:37am
Quote:
I don't think so.
Again my question,
Seems a bit contradicting. I am confused.
I assume Linear Regulator you are talking about is the one with an Analog Loop as rfcooltool points,
1. device type
2. size of device
3. vds
Reply #8 - Jun 29th, 2010, 3:46am
Mayank wrote on Jun 29th, 2010, 1:37am:
pancho_hideboo wrote on Jun 28th, 2010, 7:07am:
Right.
But from practical point of view, there is no remarkable affects for PLL characteristics at all, as far as voltage change is small and static.
Actually I change supply voltage from 1450mV to 1650mV by digital adjustment of feed back resistor ratio in linear regulator.
For such small voltage change, there is no remarkable change of bandwidth and gain of feedback loop.
And I can't observe any degradation of PLL characteristics as far as voltage change is static.
Mayank
Reply #9 - Jun 29th, 2010, 5:15am
Quote:
Right.
Agreed. But then all you are doing is using an digital Calibration of FB resistor over an Analog Loop.
MOSMAN initially quoted :
That Analog Loop is very much there.
All you are doing is Calibrating your output voltage, but the loop which regulates your FB voltage is unchanged. Hence, the noise introduced in unchanged.
So, the noise from the Analog Loop is very much there, since the Loop is present.
As far as question of Digital Stepping is concerned,
As we both said, it's not gonna unlock the PLL.
You are simply over/under driving the VCO, or in other words, varying oscillator VDD, so as to vary the output Frequency by a factor of Kpushing.
VCO can also be calibrated in other ways, like bands in I_tail_current, Cap load on osc nodes, etc. etc.
you are using VDD stepping, which is perfectly fine, is one of them.
Hence, MOSMAN,
you can use digitally trimmed voltage supply from an Analog Linear Regulator. BUT the noise from the Analog Loop will be present as the Loop itself is there.
Mayank.
Reply #10 - Jun 29th, 2010, 5:29am
Mayank wrote on Jun 29th, 2010, 5:15am:
I can't understand what you want to say.
Again there is no remarkable affects for both loop frequency characteristics and also PLL characteristics, even if I change feedback resistor ratio in linear regulator.
Maybe you are misunderstanding.
Purpose of increasing vdd at high temperature is keeping output amplitude of VCO from being small not calibrating frequency of VCO or Kvco.
Hence, MOSMAN,
From practical point of view, No.
Mayank
Reply #11 - Jun 29th, 2010, 8:52pm
Digital Calibration would not affect PLL characterstics. Agreed.
But mosman was saying,
To that, Analog Loop is still present, right. You are changing FB resistor ratio, so as to step up/dn output voltage. Hence, there is no removal of noise in using digital calibration just like there is no excess noise introduction. The noise i am talking about is the one from the opamp, The PMOS DRIVER & the resistors shaped by the Analog Loop.
Got it. It can also be employed to vary VCO frequency bands.
Reply #12 - Jun 30th, 2010, 4:53am
Mayank wrote on Jun 29th, 2010, 8:52pm:
Contributions of such noises to PLL are almost unchanged, even if I change feedback resistor ratio in linear regulator.
pancho_hideboo wrote on Jun 29th, 2010, 5:29am:
Again read the following.
pancho_hideboo wrote on Jun 26th, 2010, 2:08am:
Mayank
Reply #13 - Jun 30th, 2010, 5:10am
I guess we both are stressing the same points.
Thats what i want to convey. The noise from Analog Loop is present & FB resistor ratio doesnt change this noise much.
aLittleKnowledge
Reply #14 - Jul 13th, 2010, 4:38am
A digitally adjusted linear regulator is just the same as a linear regulator where the selection components are adjusted digitally.  If you can leave the regulator setting unchanged during the times that you are interested in the noise levels there should be no noise introduced due to the fact that the regulator is digital.  If this is possible it will avoid some design complexities such as resonances in the regulator control loop.
If the digital regulator output needs to be adjusted while you are interested in the signal frequency, there will be a quantifiable jump in the output frequency.  Acceptability is a matter for calculation.
Pages: 1 2
