jbdavid
Randomized testing is required when development of directed tests to support all cases will take too long, where could be useful in Analog verification is for packet generation for end-end testing of a mixed signal/ rf PHY.
or at block level model verification when simulating all combinations of the digital controls is impossible vs the schematic - but if there are that many controls you are probably writing your model at the wrong level.
Code, and (especially) TEST/ Feature coverage are essential. Of course you'll run these tests on the verification model of the design, without any actual transistors in the simulation. IMO , if your AMS/RF verification team is NOT using coverage metrics to find the holes in their tests, and your chip/ip block is more than 1 integer pll or ADC/DAC, you are probably wasting $$ if you pay to get masks made, and order silicon!
thats this man's opinion!
