Jul 5th, 2025, 10:18pm
Analog verification needs vs digital (Read 4740 times)
love_analog
Jul 29th, 2010, 7:22am
Digital verification teams talk about 2 things that I *believe* are not standard in AMS methodologies
a) random testing
b) coverage metrics.
Other things are covered well - top-down and directed functional verification.
What are these and what can be done to provide them as a standard flow for AMS validation.
Ken, I don't know if this should be part of this forum or another so I'll post in the other board as well.
loveanalog.blogspot.com
The Power of Analog
jbdavid
Re: Analog verification needs vs digital
Reply #1 - Nov 10th, 2010, 11:44pm
Randomized testing is required when development of directed tests to support all cases will take too long, where could be useful in Analog verification is for packet generation for end-end testing of a mixed signal/ rf PHY.
or at block level model verification when simulating all combinations of the digital controls is impossible vs the schematic - but if there are that many controls you are probably writing your model at the wrong level.
Code, and (especially) TEST/ Feature coverage are essential. Of course you'll run these tests on the verification model of the design, without any actual transistors in the simulation.
IMO , if your AMS/RF verification team is NOT using coverage metrics to find the holes in their tests, and your chip/ip block is more than 1 integer pll or ADC/DAC, you are probably wasting $$ if you pay to get masks made, and order silicon!
thats this man's opinion!
jbdavid
