Jul 17th, 2024, 7:33pm
Pages: 1 2
Phase margin in open loop and close loop (Read 19939 times)
Re: Phase margin in open loop and close loop
Reply #15 - Aug 12th, 2010, 1:59am
Attachment 1: Voltage Loop Gain Testbench
Frank Wiedmann
Munich, Germany
Reply #16 - Aug 12th, 2010, 2:06am
Phase margin only makes sense with respect to the loop gain of the circuit (and so indeed is only one parameter). For simple circuits like your example, the loop gain can be simulated by physically opening the loop. In general, however, it will be difficult to apply the correct operating points and impedances at the opening, so that the methods developed by Middlebrook or Tian are recommended. If the voltage and current sources inserted by these methods correspond to an "opening" of the loop is probably more of a philosophical question.
Reply #17 - Aug 12th, 2010, 2:27am
Comment,
  Please review the attachment, it shows the testbenches and the
results for measuring the loop gain of an amplifier using Middlebrook's
method. In addition, the dc sweep results and the transient results
for the current mode testbench are shown. The testbenches are closed
loop testbenches and the parameter of interest is the loop gain of the closed
loop system.
Reply #18 - Aug 12th, 2010, 2:28am
Part II
Reply #19 - Aug 12th, 2010, 2:28am
Part III
buddypoor
Bremen, Germany
Reply #20 - Aug 12th, 2010, 3:13am
Hi Sheldon,
thank you for the simulation results you have sent.
However, they contain not really some new information for me.
Therefore, I have problems to consider these graphs as an answer to my extensively described opinion.
Moreover, I am a bit confused cause I don't know what to do or how to comment the graphs.
For my opinion, the best way to discuss a technical matter is to ask and to answer questions.
Therefore, what is your comment to my last posting and the attachement? Anything wrong?
By the way, may I direct your attention to Tian`s & Kundert's paper (that, more or less is an extension of Middlebrook's method)?
It contains several times the phrase "broken loop".
Examples:
page 31, right columne, line 5
page 33, right columne, line 5 to 8 in "Null Double-Injection Technique"
page 34, right columne, line 7 below eq. (13) and line 8 above eq. (14)
_______________
Kind regards
Lutz
aaron_do
Reply #21 - Aug 12th, 2010, 3:20am
from the schematic it seems that vf = vn + vac, where vac is the ac voltage that has been inserted into the closed loop system. So I personally can't see how you can simulate loop gain like this. I'm definitely going to try it myself however, and if I'm wrong then thanks for the info.
btw did you simply run an AC analysis? Also how do the results compare with stb analysis. I don't have access to my workstation at the moment but i'll check it up later.
cheers,
Aaron
Reply #22 - Aug 12th, 2010, 8:06am
Buddypoor,
  Guess I need to invoke Occam's Razor
  Your "open loop" testbench is basically the closed loop testbench with
the loop broken. It implicitly assumes that the loop is closed since the
input voltage source is tuned to force the amplifier output to the
appropriate voltage. Both testbenches give the same results, see the
attachment. As implemented this testbench can not be used for corner
analysis, parametric sweeps, Monte Carlo analysis, ... because the
input voltage needs to be manually tuned. The good news is that both
testbenches produce the same results.
Reply #23 - Aug 12th, 2010, 8:09am
Additional comment:
The current "open loop" testbench is difficult to use because of the
manual tuning required to set the dc operating point. Attached is a
modified version of the testbench that has a stable dc operating point.
It uses analysis dependent to close the loop for the dc operating point
calculation and to open the loop for the loop gain simulation.
buddypoor
Bremen, Germany
Reply #24 - Aug 12th, 2010, 8:51am
Hi Sheldon,
Thanks for the reply, however I didn't get everything, as for example
the loop broken.
Maybe, the reason is my limited knowledge of your language.
appropriate voltage., ...
because the
No, there is no need to tune any voltage manually. Both schemes ( I didn't invite them!) do not require any "tuning". But - I am aware that the second "test bench" in my former pdf attachement does not work properly for real opamps. It was used only to demonstrate that the first scheme (simplified Middlebrook) produces exact the same input/output voltages resp. the same ratio as the "classical and robust" open-loop method.
Anyway, thanks for the discussion.
Remember the original question if there are two phase margins (open resp. closed loop): I think, at least this question has been clarified.
It would be interesting to hear from the forum member who has posted the question if he is satisfied now.
Thank you and regards
Lutz
newic
Reply #25 - Aug 12th, 2010, 9:17pm
Very impressive discussion.
I really learn a lot from this forum.
Thank you very much   Smiley
Pages: 1 2
