May 2nd, 2024, 11:27pm
Problem with performing DFT in SPECTRE cadence (Read 4192 times)
Nandish Mehta
Feb 21st, 2011, 1:51am
Hi Friends,
I am design a boot strapped switch and trying to measure distortion by looking at the DFT.
My input is 3 MHz sinusoid and the sampling clock is 20 MHz.
When i do dft of input, i expect only single tone. However to my surprise i find multiple tones.
Can any one please comment on this? Please suggest a solution on how to take a proper DFT.
Nandish
aaron_do
Re: Problem with performing DFT in SPECTRE cadence
Reply #1 - Feb 21st, 2011, 5:10am
Hi Nandish,
are you probing the voltage of an ideal voltage source? Also over what period of time did you take the DFT? Why don't you try PSS or QPSS analysis?
cheers,
Aaron
Nandish Mehta
Reply #2 - Feb 21st, 2011, 6:27am
hi aaron,
I am not sure how to use .pss analysis for calculating the distortion of a boot strap switch.
My simulations setting information is as below:
1) Input is from ideal sinusiodal voltage source with 3 MHz freq.
2) Sampling frequency for sample and hold is 20 MHz
3) Simulation is ran for 10us
4) 1024 point DFT is calculated with rectangular window
I have came to know that the error i am facing is called spectral leakage. I am not sure how to manage it. I tried changing the spectral window but it didn't work.
Please suggest me some solution if you know.
Thanks for your response.
Nandish
Frank Wiedmann
Munich, Germany
Reply #3 - Feb 22nd, 2011, 12:30am
Nandish Mehta
Reply #4 - Feb 22nd, 2011, 5:02am
Thanks for the link Frank.
