May 4th, 2024, 6:13pm
calibre parasitic extraction problem (Read 4346 times)
Tiger
Apr 10th, 2011, 1:22am
hi, all.
I came across parasitci extraciton problems when using calibre, hope someone can help me:
The process i used provides deep nwell(DNW) for pusb isolation. So for some NFETs, I had S and B connected together to a different potential(net, suppose its name is Vx) from Gnd.
When run calibre c+cc parasitic extracion, i found the parasitic lumped capacitors of  these NFETs, which are supposed to these isolated psub(net Vx), are to the whole pusb(net Gnd)~ Obviously, this is not correct.
So, how can i extract the parasitic capacitors correctly?
many thanks!
Tiger
boe
Re: calibre parasitic extraction problem
Reply #1 - Apr 11th, 2011, 10:26am
Tiger,
is your layout correct? I.e. does it have all guard rings etc. that your technology requires?
Did you test a single transistor?
B O E
Tiger
Reply #2 - Apr 11th, 2011, 8:00pm
Boe,
the layout is correct, and it is about different ground regions  but the netlist is showing just one, which can be solved "Multiple Ground Regions" option.
And now, I've fixed my problem,  which is just caused by the wrong "ground layer" name~
