Apr 29th, 2024, 11:47am
Pages: 1 2
How to reduce 1/f noise in BandGap (Read 29792 times)
analog_wiz
Universe
Re: How to reduce 1/f noise in BandGap
Reply #15 - Nov 30th, 2012, 12:26am
You can also use on chip RC (Small area no external components) filters to
filter out the noise.
Reply #16 - Nov 30th, 2012, 1:39pm
analog_wiz wrote on Nov 30th, 2012, 12:26am:
Flicker noise is generally DC and near DC,
so filtering does not get you much other than limiting the BW a bit.
Google and IEEE Explore will be your research sources.
analog_wiz
Universe
Reply #17 - Nov 30th, 2012, 7:37pm
To Optimize a BG for noise will include reducing both (thermal as well as flicker). You can use (on chip rc using special techniques) to get cutoffs as low as 500hz(3db).Loose electron, have you used any other techniques other than those discussed here.
RobG
Bozeman, MT
Reply #18 - Nov 30th, 2012, 7:44pm
analog_wiz wrote on Nov 30th, 2012, 7:37pm:
The original poster was concerned with bandwidths less than 20 Hz. To do that your options are pretty much larger devices, correlated double sampling or chopping.
analog_wiz
Universe
Reply #19 - Nov 30th, 2012, 8:26pm
OK Robg. Thanks for getting me back to the topic. Also do you have any no's for integrated noise for frequencies upto 10k with chopping.what kind of applications will need that kind of low noise from bandgap.high resolution adc's?
RobG
Bozeman, MT
Reply #20 - Nov 30th, 2012, 8:56pm
analog_wiz wrote on Nov 30th, 2012, 8:26pm:
Sorry, I don't have any numbers off the top of my head.
raja.cedt
Reply #21 - Dec 1st, 2012, 1:08am
hello all,
please the following website papers, you get real numbers and current state of art.
http://wwwetis.et.tudelft.nl/people/biography/projectleaders/makinwa_kofi/public...
Raj.
Reply #22 - Dec 1st, 2012, 3:58pm
After you got a BG adjusted where you wanted (curvature correction, offsets and all that)
To the best of my knowledge you got:
Bigger W & L for lower flicker
Lower impedance, higher currents for lower White-thermal-johnson noise.
Chopping to up-convert the near DC noise flicker noise
Bipolar design to get away from MOS flicker noise. (reminder - BJT
devices have flicker noise as well, just orders of magnitude
smaller than MOS devices)
Filtering output
Filtering select nodes in the BG
That's what I am aware of.
Kevin Aylward
Reply #23 - Jul 6th, 2013, 7:44am
Use a process with a half decent bipolar. This incessant drive for cmos only is pretty much daft. Many “cmos” processes actually do have a decent bipolar. Just avoid those silly 45nm ones. Who wants to do analog with a few atoms of silicon anyway…
Kevin Aylward
Venky_analog
Analog Design is my
trade. Math is my
love.
TX, USA
Reply #24 - Feb 3rd, 2016, 6:23pm
I have a question here. How can source degeneration reduce flicker noise? If it's because of the reduction in the 'gm' of the transistor, then isn't it going to affect the signal by the same amount, thereby keeping the SNR the same?
Either die a white noise or live long enough to see yourself become the 1/f noise.
RobG
Bozeman, MT
Reply #25 - Feb 3rd, 2016, 8:02pm
Venky_analog wrote on Feb 3rd, 2016, 6:23pm:
In this case it is a current mirror that doesn't have a signal - just noise.
In general, for a given DC current, the larger the gate voltage, the lower the noise. So start out with the assumption that we have made the gate voltage as large as headroom will allow. There are two ways you can get this large gate voltage:
1) Small W, large L (gives a large Vgs-Vt)
2) Large W, small L and resistive degeneration
If the total W*L is the same for both cases then (2) will have less 1/f noise current because its gm is less.
The optimum for noise would be to use a really wide device with minimum length, however, that maximizes drain capacitance and minimizes output impedance so there is a trade-off.
DanielLam
Reply #26 - Feb 5th, 2016, 12:40pm
Source degeneration can reduce both flicker and thermal noise (and any other noise produced by that transistor). First, you must understand why the noise of a cascode does not matter much. Then apply this thinking to the source degeneration case. They are very similar, just one has a degeneration resistor instead of a degeneration ro.
Assume there is a noise source at the input of the cascode, what happens to its gain as you increase the source impedance/resistance?
The cascode case is described in Razavi's book in the noise chapter.
Pages: 1 2
