vin
Hi All
I designed a digital frequency divider for my crystal oscillator(Fosc=20M) output to be divided by 2 . Basically a D flpflop in feedback configuration, when I run phase noise sims on divider alone in spectre RF i was getting -170db noise floor.
My crystal oscillator when running at 20M (i.e undivided) does have a floor of -160db. When i connected the divider i expect 6db improvement in floor for divided by 2 function which 20log(2), instead what I am getting is 10db worse than undivided noise floor. I tried different divider toplogies like DFF , master slave DFF, TSPC DFF but all of these are showing me worse noise floor than undivided output.
I do know powersupply noise do effect the divider phase noise and replaced the supply with ideal voltage source. Iam aware of broadband noise at the input of the divider get aliased so tried flitering the noise at the input of divider but the result is no improvement.
I cant understand how a 170db noise floor divider put into oscillator can degrade the phase noise? am I missing anything here?
pss setup when divider switched in is fundmental is 10MHz and selecting the output node as divider output.
can anybody have any thoughts on this?
Regards Vin
