Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
May 19
th
, 2024, 4:19am
Home
Help
Search
Login
Register
PM to admin
Modeling
Behavioral Models
› voltage limited current source
Previous topic
Next topic
voltage limited current source (Read 1330 times)
danmc
Boston
Aug 17
th
, 2011, 6:29am
Sometimes it is useful to have a verilog-a or AMS model for something like a bias current generator but in those cases it is also good to provide voltage limiting. Is there a simple way to do this in Verilog-A or Verilog-AMS? The issue is that without voltage limiting, the current sources will simply force the current no matter what and sometimes that is really not what the rest of the circuit wants!
In the past I have done some stuff in spectre with hanging additional controlled sources that have limiting on my output node.
-Dan
IP Logged
boe
Re: voltage limited current source
Reply #1 -
Aug 17
th
, 2011, 12:39pm
Danmc,
you can do something like
if (V(ibias, vss) > 1) I(ibias, vss) <+ CurrentValue; else I(ibias, vss) <+ 0;
However, for better convergence you should avoid the discontinuity of the current and use a soft transition.
B O E
IP Logged
danmc
Boston
Reply #2 -
Aug 17
th
, 2011, 1:17pm
you mean use something like like a tanh function instead of hard compare?
IP Logged
Reply #3 -
Aug 17
th
, 2011, 3:46pm
I don't recommend following BOE's suggestion. That is a recipe for convergence problems. I have seen two approaches to this problem that works well. One is to carefully model current/voltage limiting. You can use
http://www.designers-guide.org/VerilogAMS/functional-blocks/regulator/regulator....
as a model. Alternately, you can model a two terminal clamp that you place in parallel with the current source. It would have infinite impedance within the compliance range of the current source, but then would look like a small resistor outside that range. It would be designed so that the IV characteristics were piecewise continuous.
IP Logged
boe
Reply #4 -
Aug 18
th
, 2011, 3:25am
danmc wrote
on Aug 17
th
, 2011, 1:17pm:
Yes; and that seems to work quite well, too.
B O E
IP Logged
danmc
Boston
Reply #5 -
Aug 19
th
, 2011, 8:36am
Ken Kundert wrote
on Aug 17
th
, 2011, 3:46pm:
Thanks Ken. I read those 2 pages from your book (which was only about arms length away) and implemented 2 boundaries instead of 1 and it seems to work like a champ.
Thanks again.
-Dan
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
»» Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
