May 3rd, 2024, 5:06pm
AMS-ADE multiple sdf command files (Read 3782 times)
Kamal
Sep 20th, 2011, 1:20am
Hi All,
I am running mixed-signal simulation and in my design I have 3 digital blocks.
For each digital block I have a .sdf file, a .sdf.X file & a .cmd file.
In AMS-ADE=>Simulation=>Options=>Compiler=>Use sdf command file I can put the sdf command file for one digital block.
How can I proceed to select the 3 sdf command files during the simulation?
« Last Edit: Sep 20th, 2011, 2:29am by Kamal »
boe
Re: AMS-ADE multiple sdf command files
Reply #1 - Sep 20th, 2011, 3:12am
Kamal,
An SDF command file can consist of several sections to annotate different portions of your design. See documantation.
B O E
Kamal
Reply #2 - Sep 22nd, 2011, 6:18am
I finally copied the 3 sdf command files in one sdf command file, each separated by a ";" and it works  :).
Kamal
