Jul 16th, 2024, 6:40pm
how to create an n-stage RC filter in Verilog-A (Read 7508 times)
sorgin1
Feb 01st, 2012, 11:10am
The following code for a 2-stage RC filter in the following code works ok.
`include "discipline.h"
module rc_ladder(in, out, gnd) ;
  inout in,out,gnd;
  electrical in,out, mid,gnd;
  parameter r=1k ;
  parameter c=1n ;
  analog begin
      // stage 1
      I(in,mid) <+ V(in,mid) / r;
      I(mid,gnd) <+ ddt( V(mid,gnd) * c );
      // stage 2
      I(mid,out) <+ V(mid,out) / r;
      I(out,gnd) <+ ddt( V(out,gnd) * c );
The next step would be use a for loop to create as many stages as I want. I tried using the following code, but fails at compile.
module rc_ladder_forloop(c[0],c[2], gnd) ;
  inout c[0],c[2], gnd;
  electrical [0:2] c;
  electrical gnd;
  parameter r=1k ;
  parameter c=1n ;
  genvar k;
  analog begin
      for (k=1; k<2;k=k+1) begin
        I(c[k],c[k+1]) <+ V(c[k],c[k+1]) / r;
        I(c[k+1],gnd) <+ ddt( V(c[k+1],gnd) * c );
Any suggestions on how to fix this?
The next step would be to pass the number of stages as a parameter. Would that be possible? and how?
Thanks in advance.
Regards, sorgin
boe
Re: how to create an n-stage RC filter in Verilog-A
Reply #1 - Feb 2nd, 2012, 3:30am
Sorgin1,
try the generate statement or a genvar declaration.
You may want to check in your tool vendor's documentation to what extent that is supported, especially with parametrization.
- B O E
sorgin1
[SOLVED] Re: how to create an n-stage RC filter in Verilog-A
Reply #2 - Feb 2nd, 2012, 5:53am
Thanks BOE,
I was already using the genvar method, but missed a couple of other things.
I managed to get it working even including the parameterized number of stages. The following code shows the working model, at least for smartspice.
  inout in,out,gnd;
  parameter r=1k ;
  parameter c=1n ;
  analog begin
    // stage 1
    // stage 2
// parameterized version using a for loop with genvar
module rc_ladder_forloop(in, out, gnd) ;
  parameter integer steps = 2;
  inout in,out,gnd;
  electrical [0:steps] con;
  electrical in, out, gnd;
  parameter r=1k ;
  parameter c=1n ;
  genvar k;
  analog begin
    for (k=0 ; k < steps ; k = k+1 ) begin
      I(con[k],con[k+1]) <+ V(con[k],con[k+1]) / r;
      I(con[k+1],gnd) <+ ddt( V(con[k+1],gnd) * c );
    V(con[0],gnd) <+ V(in,gnd);
    V(out,gnd) <+ V(con[steps],gnd);
and the netlist should be as follows:
Test RC-ladder loops
.verilog "./test.vams"
v1 in 0 PWL(0 0 5u 10 20u 10)
** Uncomment only one of the following two lines
** First line: fixed 2 stage RC ladder
** Second line: parameterized n-stage RC ladder
*YVLG_ladder in out 0 rc_ladder
YVLG_ladder in out 0 rc_ladder_forloop steps = 2
.tran 1n 20u
.iplot v(out)
boe
Re: [SOLVED] how to create an n-stage RC filter in Verilog-A
Reply #3 - Feb 3rd, 2012, 6:28am
sorgin1 wrote on Feb 2nd, 2012, 5:53am:
I was already using the genvar method, ...
Seems I answered a bit to quickly...
- B O E
