May 19th, 2024, 8:58am
PLL phase margin with PSS/PSTB ? (Read 4464 times)
ellarguero
Apr 10th, 2012, 10:28am
dear all,
i want to simulate the phase margine of a voltage domain behavioral model of PLL using PSS/PSTB.
i got  strange results though:
here is my schemativ annotated my components
time domain simulation works well (strobed)
but when i do pss/pstb i get strange results depicted below
i insert the probe between the loop filter and the vco
i don't know what's going wrong
please help me figuring out what's wrong
ellarguero
Re: PLL phase margin with PSS/PSTB ?
Reply #1 - Apr 10th, 2012, 12:32pm
dear all,
i added a pac analysis, the transfer function from the reference source to the output dff is -6.4K dB which means the loop is open !!!!
from where may come this probleme, i thought pss take care of the different states of the pfd
Frank Wiedmann
Munich, Germany
Reply #2 - Apr 11th, 2012, 1:21am
ellarguero
Reply #3 - Apr 11th, 2012, 9:21am
Thank you Frank,
What i conclude from the thread you gave is that the models should be smooth, i use transition filter in each of my verilog-a sources and i set both fall and rise times to 1/100th of the period. i think it's smooth enough
but the probleme still shows up
from where can come this probleme
Frank Wiedmann
Munich, Germany
Reply #4 - Apr 11th, 2012, 1:19pm
Look for the pac signal at all the nodes in your circuit and see where it disappears.
