May 6th, 2024, 5:22pm
leakage current in 65 nm CMOS Technology? (Read 4771 times)
henrytqy
Nov 04th, 2012, 7:44pm
I adopt a 100 pF MOS varactor (Area: 6000 um^2) in my ckt with the standard 65 nm CMOS Technology.  But the simulation in spectre shows the leakage current is as large as 350 nA, which is too large and unaccepted to me.
my test bench is a simple RC low pass filter with only the DC excitation.
I don't know whether my test bench is correct or the leakage current is really at that level in 65 nm.
Thanks for your help~~~
Re: leakage current in 65 nm CMOS Technology?
Reply #1 - Nov 5th, 2012, 5:42am
You should ask your foundry for measurement data; it's probably proprietary data, so others on this forum would not be able to share (even assuming the values were similar in all 65nm technologies).
henrytqy
Reply #2 - Nov 5th, 2012, 7:22am
Thanks~~~it is really at that order of magnitude.
Geoffrey_Coram wrote on Nov 5th, 2012, 5:42am:
Lex
Eindhoven, Holland
Reply #3 - Nov 14th, 2012, 2:53am
Make sure your simulation is accurate enough, and check its dependency on bias voltage to be sure you're looking at the right thing.
raja.cedt
Reply #4 - Nov 14th, 2012, 3:57am
hello,
as every one said it depends on the fab, but 350nA looks really lesser than the published one. Please refer the following jssc pap, they have reported few numbers on leakage, for 900um^2 hey have 1mA leakage current.
http://www2.ee.ntu.edu.tw/~ecl/Professor/A%20Leakage-Current-Recycling%20Phase-L...
Try to read some more from the same authors you will find few more interesting leakage numbers.
try to simulate in the following manner.
By applying 1V ac voltage source at the gate of cap and measure current through gate.
Raj.
