May 19th, 2024, 2:27am
Phase margin of a behavioral OPAMP model (Read 947 times)
Jan 28th, 2013, 6:26pm
Hi Guys,
I have a OPAMP model. To my surprise, it has 74 degree phase margin if I set GBW = 10MHz while it is 17 degree phase margin if GBW=1GHz.
Since the code is too long to be accommodated in one post, I put it in two consecutive posts.
Its compensation cap is determined by
cc  = gm1/(`M_TWO_PI*GBW*(1+1/a3));
The RHP zero and second pole are proportional to GBW. Why the phase margin decreases so much when GBW increases to 10GHz?
Frz  = GBW*pow(10,GainMargin/20);
Wp2[0] = -`M_TWO_PI*Fpxo*Fpxo/Frz;
Quote:
`include "discipline.h"
`include "constants.h"
module OpAmp(out,inp,inm);
output out;  input inp,inm;      // single-ended output, differential input
electrical out,inp,inm;
voltage n0;                      // internal filter node (voltage only).
electrical n1,n2;                // midstage & output stage nodes.
// INSTANCE PARAMETERS:
parameter real Vio=0;               // input offset voltage (V)
parameter real Rin=1e20;            // opt. input resistance (ohms)
parameter real Iib=0;               // opt. input bias current (A)
parameter real Ios=0;               // opt. input offset current (A)
parameter real Voh=5, Vol=0;        // output high & low voltage limits (V)
parameter real dVo=(Voh-Vol)/50;    // output saturation corner rounding (V)
parameter real Aol=74 from [0:120]; // DC gain (dB)
parameter real Av=pow(10,Aol/20);   // DC gain (V/V) [usu. computed from Aol]
parameter real GBW=10M;             // Gain-Bandwidth Product (Hz)
parameter real Tr=0,Tf=0;           // rise/fall times (to compute SRs) (sec)
parameter real SRP=(Tr==0)?GBW:(Voh-Vol)/Tr;  // positive slew rate (V/s)
parameter real SRN=(Tf==0)?SRP:(Voh-Vol)/Tf;  // negative slew rate (V/s)
parameter real Tdhl=1/SRN;          // delay leaving high saturation (sec)
parameter real Tdlh=1/SRP;          // delay leaving low saturation (sec)
parameter real Fpxo=GBW*10 from [GBW*10m:GBW*1K]; // freq @ phase=-180deg (Hz)
parameter real GainMargin=20 from [-30:60];   // gain margin (dB, >0 stable)
parameter real CMRR=0;              // opt. common mode rejection ratio (dB)
parameter real Rdc=200;             // output DC resistance (ohms)
parameter real Rac=Rdc/4 from [Rdc*0.05:Rdc*0.8]; // output AC res (ohms)
parameter real Isp=0, Isn=0;        // opt. output source/sink current limits
parameter integer Debug=0 from [0:3]; // [0=none, 1=params, 2=op.info, 3=iter]
// LOCAL VARIABLES:
real a3;                // DC gain from midstage to output
real Vin;               // input voltage adjusted for CM term
real Vhs;               // half-scale output voltage swing range
real gm1,ih1,il1;       // transcond & current limits for source I1
real r1;                // resistance R1
real vh2,vl2,dv2;       // voltage limits & corner size for source E2
real cc;                // coupling capacitance CC
real gm3,vc3;           // transcond and offset for source I3
real r3,ro;             // resistances R3 & RO
real ih4,il4;           // currents @ voltage limits for source E4
real I1,I2,I3,I4,I5;    // currents in five nonlinear dependent sources
real Acm;               // DC gain from CM input to differential input
real Frz;               // Frequency for RHP zero (hz)
real Wp2[0:1];          // HF pole real & imaginary part (rad/s)
// FUNCTIONS:
/////  tanh transition between two levels:  ftanh0(x,gain,ios,hi,lo)
// Output ranges from lo to hi; out=0 occurs at x=ios, so
// the function requires hi>0 and lo<0.
analog function real ftanh0;
  input x,gain,ios,hi,lo; real x,gain,ios,hi,lo;
  real dv,argos;
  begin
    dv = (hi-lo)/2;           // half of output range.
    argos = atanh(-lo/dv-1);  // argument required to get out=0.
    ftanh0 = lo+dv*(1+tanh(gain*(x-ios)/dv+argos));
endfunction
/////  Voltage limiter:  fivxlim(v,Vhi,Vlo,Ihi,Ilo,dV)
// This is a smooth dual exponential relationship (dual diode limiter).
// Specify dv much less than (Vhi-Vlo) for sharp limiting to occur.
// The voltage vs current relation will pass through the following points:
//    Input Voltage:    Vhi   Vhi-dV   (Vhi+Vlo)/2   Vlo+dV    Vlo
//   Output Current:    Ihi   Ihi/100       0       -Ilo/100  -Ilo
analog function real fivxlim;
  input v,Vhi,Vlo,Ihi,Ilo,dV;
  real v,Vhi,Vlo,Ihi,Ilo,dV;
  fivxlim = abs(Ihi)*exp(max(4.6*(v-Vhi)/dV,-30))
             -abs(Ilo)*exp(max(4.6*(Vlo-v)/dV,-30));
endfunction
Yawei
Re: Phase margin of a behavioral OPAMP model
Reply #1 - Jan 28th, 2013, 6:27pm
The second part of the behavioral model.
Quote:
analog begin
  @(initial_step) if (a3==0) begin        // only do this once...
    Frz  = GBW*pow(10,GainMargin/20);     // Right-Half-Plane Zero frequency
    Wp2[0] = -`M_TWO_PI*Fpxo*Fpxo/Frz;    // Input Stage Pole in {-re,0} form
    if (CMRR!=0)                          // DCgain from CM input to Vin
       Acm = pow(10,-abs(CMRR)/20)*((CMRR>0)?1:-1);
    a3  = sqrt(0.25+0.01*Frz*Av/GBW)-0.5; // 2nd stage gain based on RHPzero
    r3  = Rdc-Rac;                        // resistance R3
    r1  = 98*r3;                          // fix resistance on midstage
    gm1 = Av/(a3*r1);                     // midstage transcond
    ro  = Rac;                            // resistance RO
    gm3 = a3/r3;                          // outstage transcond
    cc  = gm1/(`M_TWO_PI*GBW*(1+1/a3));   // compensation cap
    ih1 = SRP*cc;                         // I1 high limit
    il1 = abs(SRN)*cc;                    // I1 low limit
    Vhs = (Voh-Vol)/2;                    // halfscale output swing range
    vh2 = Vhs/a3+Tdlh*SRP;                // VL2 high voltage limit
    vl2 = -Vhs/a3-Tdhl*abs(SRN);          // VL2 low voltage limit
    dv2 = (vh2-vl2)/30;                   // VL2 smoothing factor
    vc3 = (Vol+Vhs)/a3;                   // I3 input offset voltage
    ih4 = -vl2*gm3-Vhs/r3;                // VL4 high current limit
    il4 = vh2*gm3-Vhs/r3;                 // VL4 low current limit
// input stage parasitics:
  if (Rin<1e20) begin
    I(inp,inm) <+ V(inp,inm)/Rin + Ios/2; // input resistance & offset current
    I(inp) <+ Iib;                        // input bias currents
    I(inm) <+ Iib;
// differential & optional CM gain, plus HF pole:
  if (Acm == 0)  Vin = V(inp,inm);
  else           Vin = V(inp,inm) + Acm*((V(inp)+V(inm))/2-Vhs);
  V(n0) <+ laplace_np(Vin,{1},Wp2);
// midstage transconductance & current limiting to get slew limit:
  I1 = ftanh0(V(n0),gm1,Vio,ih1,-il1);
// midstage voltage clipping for saturation delay:
  I2 = fivxlim(V(n1),vh2,vl2,ih1,il1,dv2);
// linear gain to output stage:
  I3 = gm3*(V(n1)-vc3);
// output voltage clipping:
  I4 = fivxlim(V(n2),Voh,Vol,ih4,il4,dVo);
// output resistance with optional current limit:
  if (Isp*Isn == 0) I5 = V(n2,out)/ro;
  else              I5 = ftanh0(V(n2,out),1/ro,0,Isp,-abs(Isn));
// drive all output currents:
  I(n1)    <+ I1 + V(n1)/r1 + I2;
  I(n1,n2) <+ cc*ddt(V(n1,n2));
  I(n2)    <+ I3 + V(n2)/r3 + I4;
  I(n2,out)<+ I5;
