Hi Guys,
I have a OPAMP model. To my surprise, it has 74 degree phase margin if I set GBW = 10MHz while it is 17 degree phase margin if GBW=1GHz.
Since the code is too long to be accommodated in one post, I put it in two consecutive posts.
Its compensation cap is determined by
cc = gm1/(`M_TWO_PI*GBW*(1+1/a3));
The RHP zero and second pole are proportional to GBW. Why the phase margin decreases so much when GBW increases to 10GHz?
Frz = GBW*pow(10,GainMargin/20);
Wp2[0] = -`M_TWO_PI*Fpxo*Fpxo/Frz;
Quote:`include "discipline.h"
`include "constants.h"
module OpAmp(out,inp,inm);
output out; input inp,inm; // single-ended output, differential input
electrical out,inp,inm;
voltage n0; // internal filter node (voltage only).
electrical n1,n2; // midstage & output stage nodes.
// INSTANCE PARAMETERS:
parameter real Vio=0; // input offset voltage (V)
parameter real Rin=1e20; // opt. input resistance (ohms)
parameter real Iib=0; // opt. input bias current (A)
parameter real Ios=0; // opt. input offset current (A)
parameter real Voh=5, Vol=0; // output high & low voltage limits (V)
parameter real dVo=(Voh-Vol)/50; // output saturation corner rounding (V)
parameter real Aol=74 from [0:120]; // DC gain (dB)
parameter real Av=pow(10,Aol/20); // DC gain (V/V) [usu. computed from Aol]
parameter real GBW=10M; // Gain-Bandwidth Product (Hz)
parameter real Tr=0,Tf=0; // rise/fall times (to compute SRs) (sec)
parameter real SRP=(Tr==0)?GBW:(Voh-Vol)/Tr; // positive slew rate (V/s)
parameter real SRN=(Tf==0)?SRP:(Voh-Vol)/Tf; // negative slew rate (V/s)
parameter real Tdhl=1/SRN; // delay leaving high saturation (sec)
parameter real Tdlh=1/SRP; // delay leaving low saturation (sec)
parameter real Fpxo=GBW*10 from [GBW*10m:GBW*1K]; // freq @ phase=-180deg (Hz)
parameter real GainMargin=20 from [-30:60]; // gain margin (dB, >0 stable)
parameter real CMRR=0; // opt. common mode rejection ratio (dB)
parameter real Rdc=200; // output DC resistance (ohms)
parameter real Rac=Rdc/4 from [Rdc*0.05:Rdc*0.8]; // output AC res (ohms)
parameter real Isp=0, Isn=0; // opt. output source/sink current limits
parameter integer Debug=0 from [0:3]; // [0=none, 1=params, 2=op.info, 3=iter]
// LOCAL VARIABLES:
real a3; // DC gain from midstage to output
real Vin; // input voltage adjusted for CM term
real Vhs; // half-scale output voltage swing range
real gm1,ih1,il1; // transcond & current limits for source I1
real r1; // resistance R1
real vh2,vl2,dv2; // voltage limits & corner size for source E2
real cc; // coupling capacitance CC
real gm3,vc3; // transcond and offset for source I3
real r3,ro; // resistances R3 & RO
real ih4,il4; // currents @ voltage limits for source E4
real I1,I2,I3,I4,I5; // currents in five nonlinear dependent sources
real Acm; // DC gain from CM input to differential input
real Frz; // Frequency for RHP zero (hz)
real Wp2[0:1]; // HF pole real & imaginary part (rad/s)
// FUNCTIONS:
///// tanh transition between two levels: ftanh0(x,gain,ios,hi,lo)
// Output ranges from lo to hi; out=0 occurs at x=ios, so
// the function requires hi>0 and lo<0.
analog function real ftanh0;
input x,gain,ios,hi,lo; real x,gain,ios,hi,lo;
real dv,argos;
begin
dv = (hi-lo)/2; // half of output range.
argos = atanh(-lo/dv-1); // argument required to get out=0.
ftanh0 = lo+dv*(1+tanh(gain*(x-ios)/dv+argos));
endfunction
///// Voltage limiter: fivxlim(v,Vhi,Vlo,Ihi,Ilo,dV)
// This is a smooth dual exponential relationship (dual diode limiter).
// Specify dv much less than (Vhi-Vlo) for sharp limiting to occur.
// The voltage vs current relation will pass through the following points:
// Input Voltage: Vhi Vhi-dV (Vhi+Vlo)/2 Vlo+dV Vlo
// Output Current: Ihi Ihi/100 0 -Ilo/100 -Ilo
analog function real fivxlim;
input v,Vhi,Vlo,Ihi,Ilo,dV;
real v,Vhi,Vlo,Ihi,Ilo,dV;
fivxlim = abs(Ihi)*exp(max(4.6*(v-Vhi)/dV,-30))
-abs(Ilo)*exp(max(4.6*(Vlo-v)/dV,-30));
endfunction
Yawei
