Jul 2nd, 2025, 11:49am
Model Exponential rising signal in Verilog-A (Read 9309 times)
aliasnikhil
Feb 17th, 2013, 7:56pm
I am trying to write VerilogA model for a circuit that has an exponentially rising output response (like charging of a real capacitor). For example, if the input is a voltage pulse with almost zero rise time, then the output of the circuit should rise exponentially towards the final voltage.
I need this equation:
V_out = V_previous + (V_new - V_previous)*(1 - exp(-1*time/tau))
V_previous is the starting voltage.
V_new is the voltage that the output tries to reach exponentially.
tau is the time constant.
Can anyone please help me with this regard.
Thanks.
-Nikhil
Re: Model Exponential rising signal in Verilog-A
Reply #1 - Feb 21st, 2013, 10:15am
You could implement an R and a C with Verilog-A equations.
How are you thinking to "remember" the starting voltage?
module vexpout(in, out, ref);
inout in, out, ref;
electrical in, out, ref;
electrical mid;
parameter real R = 1 from (0:inf);
parameter real C = 1p from (0:inf);
analog begin
    I(in,mid) <+ V(in,mid) / R;
    I(mid,ref) <+ C * ddt(V(mid,ref));
    V(out,ref) <+ V(mid,ref); // output buffer
