May 3rd, 2024, 12:58am
VerilogA apply transient final conditions to AC/noise analysis (Read 5361 times)
anamania
Jun 20th, 2013, 7:49am
I have built a VerilogA module that is the AGC for an analog PGA. At the end of transient analysis, the module sets the gain of the PGA so that the output swing settles to a target value whatever the input swing is. How do I apply this gain, says 5 bit control, to subsequent AC & noise analysis? I want to complete all analysis in one simulation.
Thanks.
Re: VerilogA apply transient final conditions to AC/noise analysis
Reply #1 - Jun 21st, 2013, 6:24am
Try setting restart=no on the AC analysis, and make sure it is run after the transient analysis.
weber8722
Reply #2 - Mar 1st, 2015, 11:06am
Hi Ken,
can you give a short example spectre netlist.
I think this question is often asked.
In Cadence I typically solve the problem with ADEXL and calcVal, but a pure spectre solution would be much more elegant!
Bye Stephan
Reply #3 - Mar 1st, 2015, 12:01pm
// Test case where the AC analysis that follows a transient uses the operating
// point from the final point of the transient analysis.
simulator lang=spectre
Vin (in 0) vsource type=pulse val0=0 val1=1 mag=1
R   (in d) resistor r=1k
D   (d  0) dmod
model dmod diode
ACpre ac start=1 stop=1M
TR tran stop=1u
ACpost ac start=1 stop=1M prevoppoint=yes
