Jan 13th, 2026, 4:54am
psub_StampErrorFloat- Assura LVS (Read 1062 times)
aki
Jun 26th, 2013, 12:27am
Please Help!!
I am working on a low noise amplifer (LNA). In the schematic I used rplpoly_rf resistors of TSMC foundary. I generated the layout from Tools-> Design synthesis -> Layout XL. My DRC was cleared and LVS as well. However, Error Layer Window (ELW) popped up and pointing to every resistor that "psub_StampErrorFloat". I have no idea how to solve it. Could you please help me to solve this?
Thank you so much.
purplewolf
Re: psub_StampErrorFloat- Assura LVS
Reply #1 - Jun 26th, 2013, 3:39am
Either your psub is floating or you have to draw its layers by yourself in layout and then connect it to ground.
bernd
Munich/Germany
Reply #2 - Jul 1st, 2013, 3:52am
Your “rppoly_rf” resistor is probably a 3 terminal resistor which needs to be connected
with the 3rd terminal to PWell or Psub. For some cases VXL cannot handle and does not
recognize such connections automatically.
Check if you need a 3rd connection to PWell or Psub  with the resistor and
if  this connection exist in your layout.
* bernd
Just another lonesome cad guy
