Jul 16th, 2024, 1:40am
post pex simulation: specre netlist versus calibre netlist (Read 4850 times)
nereo
Jul 17th, 2013, 7:59am
Hello everyone,
i'been experiencing some difference in spectre simulation results depending on which type of post pex netlist is created.
to track down the problem i've created a simple testbech.
My schematic is a capacitor with a switch transistor connected at the bottom plate. I've created a DRC and LVS clean layout.
I first do a PEX creating a calibreview output. Then i do a PEX creating only a spectre netlist output. Both PEX are same.
After a s-parameter simulation in order to check the capacitance seen at the  top plate I gete a 70 aF difference depending which netlist is used. (NMOS switch with grounded source and bulk is turned on).
Where could this difference come from? Please help me with some suggestions...  :)
Thanks in advance
boe
Re: post pex simulation: specre netlist versus calibre netlist
Reply #1 - Jul 23rd, 2013, 3:48am
nereo,
are the sim netlists the same?
- B O E
nereo
Reply #2 - Aug 5th, 2013, 1:24am
Dear BOE,
thank you for your answer. Sorry for a late reply...i'll be faster from now on  :)
The netlists are different in terms of port node naming, but are the same when I compare the values of parasitic capacitors and resistors. Also, the device parameters and their values are the same.
nereo
boe
Reply #3 - Aug 9th, 2013, 1:43am
nereo,
logically identical netlists should give the same results. I suppose you already checked that you used the same simulator settings.
Is it possible that this is just numerical error (eg. [numerically] unstable initial conditions, ...)?
- B O E
