Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 18
th
, 2024, 11:12pm
Home
Help
Search
Login
Register
PM to admin
Simulators
AMS Simulators
› how to create config view and simulate verilog-AMS code
Previous topic
Next topic
how to create config view and simulate verilog-AMS code (Read 311 times)
susona
Aug 15
th
, 2013, 3:55am
hai all
I am new to use AMS. presently we equipped with Cadence IC614 dfII enivronment. i wanted to code SAR ADC in verilog-AMS so before that i just taken the verilog-AMS code listing 12 from this forum and try to simulate it but i am getting errors in the simulation.
i used ADE and try to simulate then also i am getting the errors so can any one tell me how to run verilog-AMS code and test bench using virtuoso ADE
the other thing is can we attach verilog-ams to a technology file like 65nm or 180nm technology
how to get the power estimation from the verilog-AMS code
i am reading the help notes and trying but not able to solve errors if any one can help thanks in advance
Susona
IP Logged
susona
Re: how to create config view and simulate verilog-AMS code
Reply #1 -
Aug 15
th
, 2013, 9:06pm
please some body reply me how to do that
IP Logged
visbi
Bay area,SF
Reply #2 -
Aug 19
th
, 2013, 3:40pm
First create the schematic (any other view) from Library Manger. Then in the same file again create config view and select Hierarchy in Open with.
Then use the template of AMS. In view select the schematic.
Visbi
Always in hurry
IP Logged
susona
Reply #3 -
Aug 19
th
, 2013, 8:24pm
can you explain how to attach technolgy file to verilog -ams code and also to calulate the power consumption for the behavioral verilog-ams code
IP Logged
Reply #4 -
Nov 9
th
, 2013, 4:22am
Susona,
When creating library for a purely behavioral modeling purposes,
a technology file is not required. You can select none.
IP Logged
girishnani
Reply #5 -
May 1
st
, 2014, 2:48am
hello, i have done all these steps config. and everything.. i was strucked at connecting rules when i add ams setup it doesn;'t show any connecting rules. how to add connecting rules. without those rules it is showing error. please help me.
IP Logged
boe
Reply #6 -
May 7
th
, 2014, 8:16am
Girishnani,
you should start with reading the relevant tutorials. The connect rules should be installed and included in the lib list.
- B O E
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
»» AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
