May 18th, 2024, 10:26pm
Solving a differential equation using VerilogA Model (Read 3492 times)
Ricky Chen
Sep 19th, 2013, 7:06am
Dear All,
I need to solve a differntial eqaition in my VerilogA marco-model
The eqaution I want to solve is:-
ddt(V(alpha)) = Vx * V(in)
V(in) is the input signal ( as a function of time 't')  to the model.
Vx is read from a "table_model" at (t + V(alpha) i.e (  $(abstime) + V(alpha)  )
To solve this  I did as below:-
// define branches
branch (alpha) alpha1;
branch (alpha) alpha2;
I(alpha1) <+ -Vx * V(in);
I(alpha2) <+ ddt(V(alpha));
 The KCL at alpha forces I(alpha1) + I(alpha2) = 0  and solve the differntial equation.
I went and checked the results.
At  $abstime = t1
    Vx * V(in)= x1
    V(alpha)= y1
At  $abstime = t2
    Vx * V(in)= x2
    V(alpha)= y2
I think y2 should be equal to
        y2= [ x2 * (t2 - t1) ]  + y1.
But SPECTRE is showing something different than "y2" .
Can anybody please tell where I am going wrong ?
Whether my line of thought is correct ?
or it may be some accuracy issue of Spectre lile Reltol, Vabstol,Abstol playing some rule ?
Also I solve the above differntial eqaution using MATLAB ODE45().
It is totally different from the SPECTRE result !
Kind Regards,
« Last Edit: Sep 19th, 2013, 11:43am by Ricky Chen »
boe
Re: Solving a differential equation using VerilogA Model
Reply #1 - Sep 23rd, 2013, 12:52am
Ricky Chen wrote on Sep 19th, 2013, 7:06am:
Dear All,
// define branches
[Added:] dValpha(t)/dt = f(Valpha(t), t) * Vin(t), right?
At  $abstime = t1
    Vx * V(in)= x1
    V(alpha)= y1
At  $abstime = t2
    Vx * V(in)= x2
    V(alpha)= y2
I don't think so.
Did you try an "indirect branch assignment statement"?
- B O E
« Last Edit: Sep 23rd, 2013, 8:22am by boe »
