Battosai
Switzerland
Hello
I am currently composing a liberty timing file for an analog block to be used in a larger digital simulation. The pin description for most pins are only described by their direction, capacitance and rise_ -and fall_capacitance. What I can't figure out is how these latter values are defined? Should these values represent the equivalent capacitance that generates the same rise and fall times?
