Feb 16th, 2026, 9:01pm
Interaction between blocks and analoglib (Read 7040 times)
Davivilla
Mar 04th, 2014, 10:44am
I am using cadence IC 5.10 for create verilog-a model.
But when i try to mix verilog-a and elements of analoglib or other lib,
there is no interaction.
i have attached a screen of a simple circuit.
when i simulate to see the potencial or flow. Apparently does not recognize the R0 r:1k from analoglib.
Thank you
Re: Interaction between blocks and analoglib
Reply #1 - Mar 5th, 2014, 1:51am
It's highly likely that there's something wrong with your resistor verilogA model, rather than it being a problem with the analogLib res component (which just netlists to a spectre resistor component). That said, the fact that your VerilogA model is also called resistor might case problems because it clashes.
I just tried this. If I look at my netlist, I get this:
I2 (net4 0) resistor R=20
I1 (pos net4) resistor R=100
R0 (net4 0) resistor r=1K
V0 (pos 0) vsource type=sine ampl=100m freq=100K
If your VerilogA module has a parameter with a capital R, then the r=1k on the primitive resistor will be ignored and the default value will be used.
Note that spectre reports this:
Warning from spectre during circuit read-in.
   WARNING (SFE-2654): VerilogA module `resistor' override primitive/(verilogA module) `resistor'.
So that's my guess at what's happening, based on the limited information that you've provided.
Not sure this is really an "Entry Tools" problem, but Ken can move the post if he sees fit.
Reply #2 - Mar 5th, 2014, 1:53am
Er, whoops - it was Ken who moved it into Entry Tools in the first place. Sorry  :'(
Davivilla
Reply #3 - Mar 6th, 2014, 1:03pm
Hi Andrew,
You are rigth, i changed the name and parameter of the model resistor it works !!! Thank you.
Now i have another question. i try with a opamp model:
`include "constants.vams"
`include "disciplines.vams"
module CommonSource_VA_simple(IN, OUT);
     inout IN, OUT;
     electrical IN, OUT;
           parameter real ganancia=1.8464;
                 analog begin
                 V(OUT) <+ V(IN)*(-ganancia)+3.76;
At the output of the model i need to see the bandwidth then i put a capacitor of analoglib.
But the same problem appears. The capacitor does not interact with the model of verilog-a.
According to the simulation I have an infinite bandwidth.
what do you think is the problem with this interaction?
Davivilla
Reply #4 - Mar 6th, 2014, 1:11pm
This is my simulation.
Both are analyzed in the "out"  of the mode.
AC an transiet.
boe
Reply #5 - Mar 7th, 2014, 12:28am
Davivilla,
your model describes a voltage-controlled voltage source. So, of course the gain does not depend on frequency or load cap.
- B O E
Davivilla
Reply #6 - Mar 10th, 2014, 4:52am
I really appreciate this.
Thank you very much.
Did I want to know if you can help me with a design in this topic?
Best regards
Davivilla
Reply #7 - Apr 7th, 2014, 4:25pm
how can i do an interaction with other components?
i have tried for a long time and i dont know how to do.
please ! !
Reply #8 - Apr 8th, 2014, 2:03am
Unless you describe what behaviour you are trying to model when you talk about "interaction with other components", it's rather hard to give some pointers!
Davivilla
Reply #9 - Apr 9th, 2014, 3:12pm
Yes sorry,
I'm trying to do a model with  multiple assignments to a port out through
V ( out ). that is for example
V(out)<+ 5:
V(out)<+ganancia*laplace_np(V(pos, neg),{1},{-6.28e6, 0, -6.28e9,0});
All the model is behavioral. there is not structural modeling.
For example.
I need the model interacts with an output load and see how it  affects the AC response.|
I need a way to read the output load in order to introduce this to the model.
Thank you.
Lucho
Bucaramanga - Colombia
Reply #10 - Apr 9th, 2014, 8:18pm
So basically what you are trying to say is that you need a way to introduce whatever is at the load of your model within the statement of your laplace filter. In other words , you need to define the frequency of your poles based on the values of capacitance and resistance seen at the output node right ?
If that is the case, as an alternative way I wonder whether the frequency response of such a model would be properly defined if you have two different contribution statements; one using your laplace filter for the "internally" defined frequency response and another one based on the fundamental equations governing R's, C's and L's.
I'll take a look at it and report on findings.
Lucho.
View Profile WWW Lucho Lucho lucho_lazaro   IP Logged
Reply #11 - Apr 9th, 2014, 11:08pm
The thing is that you are still describing an ideal voltage source - unless your model has some kind of output impedance it won't be affected by the load. If you don't know how your output looks like from an electrical perspective, then I'm not sure how you would expect to see the effect of the load on your system.
Davivilla
Reply #12 - Apr 10th, 2014, 1:36pm
Hi Andrew,
I totally understand,  but could you give me an example?.
What do you recommend for define output impedance to the next model?
// VerilogA for zamplificador, opamp_designers_guide, veriloga
module opamp_designers_guide(pos, neg, out);
output out;
input pos,neg;
electrical pos, neg, out;
parameter gain=10;
    analog begin
	  V(out)<+gain*(laplace_np(V(pos,neg),{1},{-6.28e3,0,6.28e12,0}));
Lucho
Reply #13 - Apr 10th, 2014, 1:56pm
Now I am interested in knowing if there is a way in which you could convert
Davivilla wrote on Apr 10th, 2014, 1:36pm:
into
       V(out)<+gain*(laplace_np(V(pos,neg),{1},{-6.28e3,0,-1/(2*pi*Rout*Cout),0}));
Where Rout and Cout are external (not in the verilog-a model) components connected to the output node of your amplifier. In this way, your AC response would reflect the impact of the load.
