Jul 6th, 2025, 5:14pm
How to calculate the Cp between p substrate and deep Nwell? (Read 1136 times)
Jacki
Apr 18th, 2014, 9:53am
    I want to estimate the total parasitic capacitance between the p substrate and deep Nwell. In the layout extraction, the design kits only support the diode extraction, but the parasitic capacitance is not well modeled. So I want to roughly calculate the parasitic capacitance. Can anybody recommend some unit cap value? I am using 0.18um CMOS technology.
   Thank you.
Jacki
Re: How to calculate the Cp between p substrate and deep Nwell?
Reply #1 - Apr 19th, 2014, 10:31am
By the way, how is the PN junction capacitance (Cj) changed for different CMOS technologies, like from 0.25um CMOS to 65nm CMOS? Is the unit Cj becoming larger for advanced CMOS technology like 65nm CMOS than the old CMOS technology?
Reply #2 - Apr 22nd, 2014, 1:12pm
Doesn't the diode extraction include the junction capacitance?  I would expect it to be bias-dependent and change with the VDD applied to the nwell.
Jacki
Reply #3 - Apr 23rd, 2014, 4:17pm
Geoffrey_Coram wrote on Apr 22nd, 2014, 1:12pm:
Hello Geoffrey_Coram,
   Only the devices are modeled with this junction diode, but in the region where MIM cap and guarding ring, it is not modeled. So in the parasitic extration, the total parasitic PN junction cap is not acturate.
Reply #4 - Jul 8th, 2014, 7:34am
Jacki wrote on Apr 23rd, 2014, 4:17pm:
I'm not sure I understand what you're saying.  I think you mean, in the extraction, the junction diode is only extracted under MOSFET devices (I guess it's NMOS in deep nwell).  And the extraction does not include the diode under MIM caps or guard rings.
Do you know the doping level of the psub or dnw?  Can you make some estimates of the capacitance based on the extraction of junction diodes under differently-sized MOS devices?
