Aug 17th, 2024, 11:16pm
Pages: 1 2
BGR PSRR (Read 3580 times)
RobG
Bozeman, MT
Re: BGR PSRR
Reply #15 - Sep 15th, 2014, 7:38am
I still haven't had a chance to look in depth at this - it could be a great idea - but wouldn't you get the same effect if you used a PMOS output stage with Miller compensation driving M2 and M3? (Or better, from the gate of M2/M3 to Vdd) Perhaps with an LDO you would be load compensated.
analog_rf
Universe
Re: BGR PSRR
Reply #16 - Sep 15th, 2014, 8:59am
As mentioned already ,haven't used this in case of Bandgap. For BG PSRR i would prefer using a Folded cascode dominant pole compensated and also add small load cap of maybe 10pf at output will give good psrr no's @ac.
« Last Edit: Sep 15th, 2014, 11:11am by analog_rf »
analog_rf
Universe
Re: BGR PSRR
Reply #17 - Sep 15th, 2014, 9:14am
RobG wrote on Sep 15th, 2014, 7:38am:
Miller would be a killer for ac PSRR, since dominant pole would be internal and adding more cap would cause the internal pole to be pushed  further inside for stb(you could still use cap to supply,but will not be better than fc opamp).
RobG
Bozeman, MT
Re: BGR PSRR
Reply #18 - Sep 15th, 2014, 2:16pm
analog_rf wrote on Sep 15th, 2014, 9:14am:
Miller is what they are using now, except they are using an NMOS mirror so it is referenced to the bottom rail which will make PSRR bad because the output device is basically diode connected at AC. That is why I as thinking the shielding of the Miller "diode" from the gate of M2/M3 was the real advantage.
The weather is too nice for me to do the math right now Smiley.
Re: BGR PSRR
Reply #19 - Sep 16th, 2014, 3:58pm
generally your dominant pole in the control loop is going to be the output capacitor on the bandgap voltage. it may not seem elegant to some but its worked pretty well for many years, and if the output drive is high impedance (not a source follower) it generally will not be terribly big in size.
Pages: 1 2
