analog_rf wrote on Sep 15th, 2014, 9:14am:Miller would be a killer for ac PSRR, since dominant pole would be internal and adding more cap would cause the internal pole to be pushed further inside for stb(you could still use cap to supply,but will not be better than fc opamp).
Miller is what they are using now, except they are using an NMOS mirror so it is referenced to the bottom rail which will make PSRR bad because the output device is basically diode connected at AC. That is why I as thinking the shielding of the Miller "diode" from the gate of M2/M3 was the real advantage.
The weather is too nice for me to do the math right now
![Smiley Smiley](https://designers-guide.org/forum/Templates/Forum/default/smiley.gif)
