May 4th, 2024, 10:27pm
PMOS Open drain: Lateral MOSFET vs Vertical MOSFET (Read 4931 times)
jsaenznoval
Oct 15th, 2014, 12:16pm
Hi everyone,
I'm designing a 18V supply PMOS open drain switch and I want to choose adequately my PMOS pass transistor. I have two strong candidates:
pmmc -> 20V symmetrical HV PMOS  Ron(@Vg=-5V)=73kOhm*um
ped2 -> 35V lateral p-DMOS  Ron (@Vg=-5V)  =57kOhm*um
In terms of layout I think that symmetrical devices are more area optimized. Additionally, ped2 has a lower resistance than pmmc. However, as far as I can see on the Internet, it is widely used lateral p-mos.  Can anyone help me with the disadvantages and advantages of both transistors?
What device should I choose?
Re: PMOS Open drain: Lateral MOSFET vs Vertical MOSFET
Reply #1 - Oct 20th, 2014, 4:37pm
could you better explain what you are doing?
this is a discrete transistor correct?
jsaenznoval
Reply #2 - Nov 3rd, 2014, 7:23am
Hi Jerry,
This open drain switch is to be integrated so it won't be implemented using discrete transistors. My question comes from the fact that lateral MOSFET occupies more area than vertical counterparts in the process that I'm using. Additionally, the vertical MOSFET layout is symmetric.
I want to know the differences between a lateral and vertical MOSFET and which I should be selected for my application, which is basically and on/off open-drain switch with a 1024ms pulse duration. From my point of view, I can perfectly use a vertical MOS because due application uses low frequency and switching performance doesn't matter.
Thanks!
What is your opinion?
Reply #3 - Nov 6th, 2014, 4:07pm
need to know a lot more about the foundry process being used.
frequently NMOS switches get implemented with fancy gate control voltage boosting circuits because the NMOS devices have better high current characteristics.
