May 19th, 2024, 4:47am
Connecting analog power domains in the same chip in ICs (Integrated Circuits) (Read 1076 times)
Tako
Nov 03rd, 2014, 7:42am
I have a following issue, which I didn't see in IC books: I would like to know if it is possible to send analog signals (sin waves) between two power domains in an integrated circuit. The issue looks as at the picture.
I have never had a problem with sending digital signals between two different power domains as it is done through level shifters / level converters. However, I never thought about sending analog signals between two power domains. Is it done using protection diodes as at the picture?
Of course, signal send from 3.3 V domain is limited to 2.5 V. This sinusoidal 3.3 Vpp emphasizes that signal is send from 3.3 V domain to 2.5 V domain and that maximum signal that can appear on the line is 3.3 Vpp.
Tako
Re: Connecting analog power domains in the same chip in ICs (Integrated Circuits)
Reply #1 - Nov 3rd, 2014, 8:14am
Oh my goodness . . . I had an eclipse of the mind at the end of a work day . . . Of course I can connect two power domains using capacitor + voltage divider. See the picture.
Reply #2 - Nov 3rd, 2014, 5:03pm
common strategy -
1 convert signal to a differential current (think diff pair)
2 take the differential current and terminate the two currents in a pair of resistors (or active loads) connected to the new power supply rails,
3 receive the new signal into a differential receiver
done
Tako
Reply #3 - Nov 4th, 2014, 8:38am
loose-electron wrote on Nov 3rd, 2014, 5:03pm:
common strategy -
done
Right. Good idea. A differential pair constructed with transistors from 3.3 V domain with resistors connected to 2.5 V domain.
Thanks!  :)
Tako
Reply #4 - Nov 4th, 2014, 9:02am
As an example of sending an analog signal between two different power domains see Fig. 32 and Fig. 49 here: [link](http://www.ti.com/lit/ds/symlink/afe031.pdf) . The input signal of the PGA1 is 10Vpp while the PGA2 can support input signal equal to its power domain that is 3.3 V. these two PGAs are connected through low-pass filter LPF and capacitor (C10 in Fig. 49).
raja.cedt
Reply #5 - Nov 4th, 2014, 1:53pm
Hi Toko,
As jerry pointed out, diff pair based concept is common idea. Think of a serial IO transmitter is communicating with receiver from different vendor.
Raj.
