Ken Kundert wrote on Mar 12th, 2015, 6:05pm:...if the decimation filter is represented with transistors, it would be possible to use SpectreRF to simulate the transfer functions...
THANK YOU Ken for your helpful reply! I get that using Verilog is the best way... :)
But, for the time-being, if I wish to
simulate the decimation filter in SpectreRF, can you please suggest
which particular analysis to choose? - should it be periodic transfer function (PXF) analysis ? (but, it is a small signal analysis, will it be valid here?....also, there are multiple output lines!) :-?
Any suggestion will be very helpful.
