May 2nd, 2024, 4:32pm
values of R & C in active-RC filter in sigma-delta ADC (Read 4128 times)
AZADBAKHT
Sep 16th, 2015, 4:11am
hi all
i want to design a sigma-delat ADC with 16bit resolution as 2'order loop.
i simulated it in matlab software as system level, now i want design filters loop as active-RC, but i don't know how to choice R & C values!!
can anyone help me to resolve this problem?
best of regards,
azadbakht
View Profile milad12333   IP Logged
cheap_salary
Re: values of R & C in active-RC filter in sigma-delta ADC
Reply #1 - Sep 16th, 2015, 4:53am
AZADBAKHT
Reply #2 - Sep 17th, 2015, 5:12am
tnx a lot sir cheap_salary
saralandry
Reply #3 - Nov 30th, 2015, 6:50pm
To determine the resealable values for R and C in an active RC-integrator used in a CT-DSM, you have to consider input thermal noise. feedback DAC as well as resistor have constrictions on overall input noise of the integrator. Having had noise power, you can determine the value of the resistor. And then C. You have to set the integrator pole at 1/RC. It is fairly easy.
deltasigmaADC
Reply #4 - Feb 1st, 2016, 4:05am
The scaling factor in each integrator of a CTDSM is Fs(sampling frequency). So typically 1/RC = Fs. Now you need to have feedback coefficients for each paths. In your case since second order two paths (1/s and 1/s^2). And direct path if compensated for excess loop delay.
Now these coefficients can be added to the 1/RC or at the DAC itself. That is a choice that you have to make. Typically for the first integrator R is fixed for thermal noise spec. For other integrators you can choose a R and C such that they are not too large in layout and not too small to get affected by parasitics. Also take into consideration area.
One more thing you have to take into account is the swing at the output of each integrator. Best design practice is to scale the swing to the max swing an opamp can support so that your passives won't get too big. Use node scaling for that.
These scaling factor will also come in the RC time constant of integrator.
You can watch video lectures of Dr Shanti Pavan of IIT Madras for a detailed understanding.
http://nptel.ac.in/courses/117106034/
http://www.ee.iitm.ac.in/vlsi/
