Jul 2nd, 2025, 5:49am
Nonlinear operation of small signal noise in Verilog-A (Read 1781 times)
cheap_salary
Oct 15th, 2015, 8:33am
See LISTING-8 at page-22 in the following.
http://www.designers-guide.org/Analysis/PLLnoise.pdf
Phase-domain fractional-N divider is modeled like following.
Theta(out) <+ Theta(in) / ( ratio + noise_table(...) );
I can easily understand this expression if it is for Transient Noise Analysis.
However this expression is for small signal noise analysis.
How is this expression treated in small signal noise analysis ?
I think this is Nonlinear operation of small signal noise.
Synopsys HSPICE and Cadence Spectre gives fairly different noise result.
Can it be valid such Nonlinear operation for small signal noise analysis ?
Re: Nonlinear operation of small signal noise in Verilog-A
Reply #1 - Oct 18th, 2015, 9:00am
The model in my paper is wrong. The noise_table function should not be in the denominator. It should be simply added to the output.
Sorry about that.
cheap_salary
Reply #2 - Oct 19th, 2015, 8:07am
Thanks for answering.
Another notice.
OVI Verilog-A 1.0 uses [] to specify arrays but OVI Verilog-AMS 2.0 uses {}.
cheap_salary
Reply #3 - Oct 21st, 2015, 11:17pm
order has to be 2*order because noise value in noise_table() is phase_noise**2 not phase_noise.
Quote:
Theta(out) <+ Theta(in) / ratio;
Theta(out) <+ noise_table({0,    n,
                          bw,   n,
                          fmax, n * pow((fmax/bw), 2*order)},
                         "dsn") );
Reply #4 - Oct 23rd, 2015, 1:45pm
Thanks for your suggestions. I have updated papers to incorporate them.
cheap_salary
Reply #5 - Oct 24th, 2015, 2:31am
Since the following is defined in this module.
parameter real fc = 0 from [0:inf); // flicker noise corner frequency (Hz)
I think noise implementation should be like following.
Theta(out) <+ flicker_noise(n*fc, 1, "fpn");
                           0, n,
                          bw, n,
                        fmax, n*pow((fmax/bw), 2*order)
                          }, "dsn"));
or
Theta(out) <+ white_noise(n, "wpn")
                          bw, 0,
                          }, "dsn"));
cheap_salary
Reply #6 - Feb 6th, 2016, 1:34am
cheap_salary wrote on Oct 21st, 2015, 11:17pm:
                          bw,   n,
                         "dsn") );
It has to be 2*(order-1), since it is phase signal.
For example, frequency charcteristics of MASH-111(order=3) is +40dB/dec for phase noise not +60dB/dec.
On the other hand, +60dB/dec for frequency noise.
