Apr 29th, 2024, 7:52am
modeling delays/ generate pulse (Read 6267 times)
analogrf
Oct 29th, 2015, 4:53am
My veriloga behavioural produces a short pulse when a voltage vA
crosses the a threshold vThresh. I am using the analog construct for this (with or without @cross). Unfortunately I cannot model that
pulse delay properly. The output trigOut is asserted "high" but it does
not toggle down, after the short delay.
Am I modelling the delay correctly?
analog begin
     //@(cross(V(vA) - V(vThresh),+1,0.01n))
     if ( V(vA) - V(vThresh) >= 0.0 ) begin
           $strobe("Hi");
           trg=1.5;
         V(trigOut) <+ transition(trg,10n,10n,10n);
     trg=0.0;
     V(trgOut) <+ transition(trg,1u,10n,10n);
     //V(trgOut) <+ absdelay(trg,1u)
Thanks and looking forward,
A.
boe
Re: modeling delays/ generate pulse
Reply #1 - Oct 29th, 2015, 10:27am
Analogrf,
the transition filter runs in parallel to your assignments to trg.
you need to create the pulse you want in trg, using the transition filter only to smooth out the transitions.
- B O E
Reply #2 - Oct 29th, 2015, 11:01am
You should try something like this:
analog begin
    @(cross(V(vA) - V(vThresh),+1)) begin
	  t_reset = $abstime + 10u;
	  trg=1.5;
    @(timer(t_reset))
	  trg = 0;
     V(trigOut) <+ transition(trg,0,10n);
This follows B O E's suggestion of creating the pulse you want in trg, and then using transition only to smooth it.
analogrf
Reply #3 - Oct 30th, 2015, 7:00am
Thanks BOE and Ken. The code snippets were helpful, and made
me skim through the entire manua (Cadence version)l. Some rules for Concurrency, race conditions etc., were helpful. Any other documents that you suggest might be helpful too.
analogrf
Reply #4 - Oct 30th, 2015, 7:05am
One more query: Would it be valid to read a port and write it, in the same construct, e.g. a simple example would be:
analog begin
     if (V(level) >=1.2) begin
           $strobe("detected");
           trg=1;
     V(level) <+ transition(trg,0,10n);
-AR
boe
Reply #5 - Oct 30th, 2015, 10:07am
Analogrf,
what is that supposed to achieve? But yes, syntactically that's OK.
- B O E
analogrf
Reply #6 - Nov 2nd, 2015, 9:19am
Ok, my mistake. V(level) would never change.
In the previous example code given by Ken, I just wanted to add
one more functionality: i.e. reset the voltage vA for a brief interval of ns to a given voltage 'reset', once the threshold is crossed. 'reset' voltage is also provided by another inout port. In the absence of 'trig' vA should retain its original voltage.
To do this I thought about a simple ternary operator at the end of analog construct (below the @timer) as:
V(vA) <+ (trig)? reset : V(vA);
The above code is however rather odd, as it retains the old value, in the else case. The simulator however does not like it.
In the else-condition I want to do *nothing*, such that vA retains its original value, but could not find an undefined state which I could assign to the else case of the ternary operator.
There is probably some straightforward way to achieve this, but no luck so far.
-A.
Reply #7 - Nov 2nd, 2015, 9:53am
Your intuition seems way out of whack when it comes to Verilog-A. The contribution statement is really an equation (with the constraint that the left-hand side must be a signal) rather than an assignment.
In an assignment it makes perfect sense to say:
i = i;
In doing so, you don't actually change i. But as an equation it makes no sense. It contains no information. If you try to use:
V(vA) <+ V(vA);
in the simulator you will end up with a singular Jacobian. Essentually you have more unknowns than you have equations because one of the equations you gave was defective.
Perhaps if you took a look at Introduction to Verilog-A it would help.
Of course there is another issue with what you propose. You are driving V(vA) with a voltage source, meaning that its voltage could not be affected by the outside circuit. Perhaps what you want is to add a switch. Something like
if (trg > 0.75)
    V(vA) <+ reset;
else
    I(vA) <+ 0;
. But doing so seems like a very bad idea, as you are driving your input. You are very likely to build either an oscillator or an unresetable latch.
