jovial
Hello everyone!
I wish to design a ring oscillator of 250 Hz (without using inductors and capacitors ) with two differential outputs. But the phase difference between the two outputs should be exactly 180 degrees. Also I need the output DC to be 900mV. I am using 1.8V supply voltage.
Can anyone suggest me some paper for the same??
