May 19th, 2024, 1:55am
ring oscillator with differential outputs (Read 1681 times)
jovial
Jan 19th, 2016, 11:23pm
Hello everyone!
I wish to design a ring oscillator of 250 Hz (without using inductors and capacitors ) with two differential outputs. But the phase difference between the two outputs should be exactly 180 degrees. Also I need the output DC to be 900mV. I am using 1.8V supply voltage.
Can anyone suggest me some paper for the same??
Re: ring oscillator with differential outputs
Reply #1 - Jan 21st, 2016, 8:33pm
you may want to go at a higher frequency and do digital divide down afterwards.
lots of papers in the IEEE JSSC - start there.
Google
RIng oscillators John Maneatus
that will be a good start point
