Jul 5th, 2025, 4:58pm
CIC filter model based on verilog-ams for sdadc, can't work! (Read 4539 times)
lwzunique
Nov 01st, 2018, 1:27am
hi, everyone!
I want to make a CIC filter for sdadc based on verilog ams, I realized this model in simulink, and got the right simulation result, but in verilog ams, this model can not work, because the signal in this model will exceeds the limit of simulator.
Output and IC/nodeset summary:
		     save   3	 (current)
		     save   28	(voltage)
    tran: time = 911.8 ns   (91.2 m%), step = 5 ps	   (500 n%)
    tran: time = 1.829 us    (183 m%), step = 5 ps	   (500 n%)
    tran: time = 2.747 us    (275 m%), step = 5 ps	   (500 n%)
    tran: time = 3.592 us    (359 m%), step = 5 ps	   (500 n%)
    tran: time = 4.443 us    (444 m%), step = 5 ps	   (500 n%)
    tran: time = 5.294 us    (529 m%), step = 5 ps	   (500 n%)
Error found by spectre at time = 5.45705 us during transient analysis `tran'.
    ERROR (SPECTRE-16384): Signal V(I5.net026) = 1.00084 GV exceeds the blowup limit for the quantity `V' which is (1 GV). It is likely that the circuit is unstable. If you really want signals this large, set the `blowup' parameter of this quantity to a larger value.
Analysis `tran' was terminated prematurely due to an error.
finalTimeOP: writing operating point information to rawfile.
the model is as follow:
input from sdm is +1 and -1 in matlab,so in this verilog ams model,I also using +1 and -1, the reason for this, i think, maybe,the 2’s complement for real digital cic filter' operation.
the code for z-delay:
`include "constants.vams"
`include "disciplines.vams"
module Z_INV_DIG(in, out,clk);
input in, clk;
output out;
electrical in, out, clk;
parameter real Vtrans=0.9;
parameter real tr=10p;   //rise,fall time
parameter real tt=0.1p;   //time tolerance
parameter real td=10p;   //delay time
parameter real init_outval=0;   //initial output value
integer outval;
analog begin
@(initial_step) begin
    outval=init_outval;
@ (cross(V(clk)-Vtrans, +1, tt)) outval=V(in);
V(out) <+ transition(outval,td,tr,tr,tt);
the code for divider:
// VerilogA for forWorkShop, Divider, veriloga
module DIV_VA(in, out);
input in;
output out;
electrical in, out;
parameter integer ratio=8;
parameter real VHigh=1.8;
parameter real VLow=0.0;
parameter real Vth=(1.8+0.0)/2;
parameter integer dir=1 from [-1:1] exclude 0;
parameter real td=1p;
parameter real ttol=1p;
integer count;
integer state;
analog begin
   // @(initial_step) begin
   //	count=0;
   //	state=1;
   // end
    @(cross(V(in)-Vth,dir,ttol)) begin
	   count=count+1;
	   if (count==ratio) count=0;
	   state=(2*count<=ratio);
    V(out) <+ transition(state?VHigh:VLow,td,tr,tr);
please help,thanks very much!
Re: CIC filter model based on verilog-ams for sdadc, can't work!
Reply #1 - Nov 2nd, 2018, 9:40pm
I5.net026 ?  That is the node whose voltage is going to infinity. Perhaps you should have identified it.
You appear to have a string of 4 open loop integrators. Wouldn't you expect their output to go to infinity over time?
lwzunique
Reply #2 - Nov 3rd, 2018, 12:57am
Ken Kundert wrote on Nov 2nd, 2018, 9:40pm:
if input is always >0,  integrators will make the result infinity over time, but if the input is -1 and +1, with increase and decrease, the +1 and -1 stream is from sdm_adc's output, +1 means digital 1, and -1 means digital 0.
in the matlab simulink model,as shown below:
this model works, the result is correct.
the difference between verilog-ams model and matlab simulink model is, sdm adc's order and input signal. but cic filter's clock frequency is based each other's sampling frequency.
I don't know why?
thanks !
lwzunique
Reply #3 - Nov 3rd, 2018, 12:57am
Reply #4 - Nov 3rd, 2018, 11:32pm
There is no real point to show us the Matlab results. We won't be able to understand what is wrong with the Verilog-AMS model by looking at the Matlab results.
Any DC offset will cause the results to diverge. Perhaps there is a DC offset in the signals you are using in the AMS simulation.
vincentleung
Reply #5 - Dec 28th, 2018, 6:38pm
you dont have to involve cic in your verilog-a modeling.  if you really want to check cic filtering together with analog sdm, i suggest you should save the output data of your analog sdm in cadence, and go back to matlab simulink, run a simulation using cic model together with the data you saved in cadence, which is the way i do when designing a delta-sigma adc.
