Apr 25th, 2024, 7:53pm
zi_zp() is inaccurate in Cadence Spectre (Read 3308 times)
cheap_salary
May 16th, 2019, 2:40am
We can evaluate frequency characteristics of z-domain transfer function, H(z) by using Verilog-A in Cadence Spectre.
Assume H(z) = (1-z^-1)^3 = 1 -3*z^-1 +3*z^-2 -1*z^-3
Here we have three options as expression in Verilog-A.
(1) zi_nd(V(Input), {1, -3, 3, -1}, {1}, Tsample);
(2) zi_zp(V(Input), {1,0, 1,0, 1,0}, {0,0}, Tsample);
(3) zi_zd(V(Input), {1,0, 1,0, 1,0}, {1}, Tsample);
However, only (1) can give accurate result.
See attached figure.
out1 is a result of Spectre primitive, zvcvs.
out2 is a result of (2).
Why can not (2) and (3) give accurate result ?
This is true for H(z) = (1-z^-1)^1 = 1 -1*z^-1
(1) zi_nd(V(Input), {1, -1}, {1}, Tsample);
(2) zi_zp(V(Input), {1,0}, {0,0}, Tsample);
(3) zi_zd(V(Input), {1,0}, {1}, Tsample);
My Cadence Spectre is Version 17.1.0.307.isr6 64bit -- 4 Jul 2018
"test_my_zi_nd.scs" Code:
ahdl_include "./my_zi_nd.va"
// Generated for: spectre
// Generated on: May 16 13:01:03 2019
// Design library name: My_Tools_TestBenches
// Design cell name: test_my_zi_nd
simulator lang=spectre
global 0
parameters fsample=36M
// Library name: My_Tools_TestBenches
// Cell name: test_my_zi_nd
// View name: schematic
V1 (net1 0) vsource mag=1 type=dc
E1 (out1 0 net1 0) zvcvs ts=1/fsample gain=1.0 \
polyarg=inversez sxz=none \
numer=[ 1 -3 3 -1 ] denom=[ 1 0 0 0 ]
V2 (net2 0) vsource mag=1 type=dc
I2 (net2 out2) my_zi_nd fsample=fsample
simulatorOptions options psfversion="1.1.0" reltol=1e-3 vabstol=1e-6 \
    iabstol=1e-12 temp=25.0 tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 \
    rforce=1 maxnotes=5 maxwarns=5 digits=5 cols=80 pivrel=1e-3 \
    sensfile="../psf/sens.output"
ac ac start=1k stop=100M dec=101 annotate=status
"my_zi_nd.va" Code:
`include "constants.vams"
`include "disciplines.vams"
module my_zi_nd(Input, Output);
inout Input, Output;
voltage Input, Output;
parameter real fsample = 1.0 from (0.0:inf);
real Tsample;
analog begin
   @(initial_step) begin
	Tsample = 1.0 / fsample;
   end //initial_step
   //H(z) = (1-z^-1)^3 = 1 -3*z^-1 +3*z^-2 -1*z^-3
   //V(Output) <+ zi_nd(V(Input), {1, -3, 3, -1}, {1}, Tsample);
   V(Output) <+ zi_zp(V(Input), {1,0, 1,0, 1,0}, {0,0}, Tsample);
   //V(Output) <+ zi_zd(V(Input), {1,0, 1,0, 1,0}, {1}, Tsample);
end //analog
« Last Edit: May 16th, 2019, 7:48am by cheap_salary »
Re: zi_zp() is inaccurate in Cadence Spectre
Reply #1 - May 16th, 2019, 7:47am
This doesn't answer your question, but what about zi_np?
(4) zi_np(V(Input), {1, -3, 3, -1}, {0,0}, Tsample);
Reply #2 - May 16th, 2019, 4:50pm
Have you looked at the time domain waveforms?
cheap_salary
Reply #3 - May 17th, 2019, 6:08am
Synopsys HSPICE can give accurate results for any expression.
Cadence Spectre can not give accurate results for (2) and (3).
But this is a limited case, FIR form.
(1) and (4) are also suspicious in Cadence Spectre.
All of (1)-(4) can not give correct result for more general transfer function which has both zeros and poles in Cadence Spectre.
We can not trust frequency characteristics of zi_xx() of Verilog-A in Cadence Spectre at all.
"my_zi_xx.va" Code:
module my_zi_xx(Input, Output);
parameter integer ix = 1 from [1:4];
//pragma protect
//pragma protect begin
voltage n1, n2, n3, n4;
real Tsample;
analog begin
   @(initial_step) Tsample = 1.0 / fsample;
   V(n1) <+ zi_nd(V(Input), {1, -3, 3, -1}, {1}, Tsample);
   V(n2) <+ zi_zp(V(Input), {1,0, 1,0, 1,0}, {0,0}, Tsample);
   V(n3) <+ zi_zd(V(Input), {1,0, 1,0, 1,0}, {1}, Tsample);
   V(n4) <+ zi_np(V(Input), {1, -3, 3, -1}, {0,0}, Tsample);
   case(ix)
	1 : V(Output) <+ V(n1);
	2 : V(Output) <+ V(n2);
	3 : V(Output) <+ V(n3);
	4 : V(Output) <+ V(n4);
   endcase
end //analog
//pragma protect end
"test_my_zi_xx.spi" Code:
.hdl "./my_zi_xx.va"
** Generated for: hspiceD
** Generated on: May 17 13:16:30 2019
** Design library name: My_Tools_TestBenches
** Design cell name: test_my_zi_xx
** Design view name: schematic
.PARAM ix=1 fsample=10e6
.PROBE AC
+    V(out) VP(out)
.AC DEC 101 1e3 100e6
.TEMP 25.0
.OPTION
+    LIST=3
+    ARTIST=2
+    INGOLD=2
+    PARHIER=LOCAL
+    POST_VERSION=2001
+    PSF=2
+    RUNLVL=6
** Library name: My_Tools_TestBenches
** Cell name: test_my_zi_xx
** View name: schematic
v0 in 0 AC 1
xi0 in out my_zi_xx fsample=fsample ix=ix
.END
"test_my_zi_xx.scs" Code:
ahdl_include "./my_zi_xx.va"
// Generated on: May 17 13:22:40 2019
// Design cell name: test_my_zi_xx
global 0
parameters ix=1 fsample=10M
// Cell name: test_my_zi_xx
V0 (in 0) vsource mag=1 type=dc
I0 (in out) my_zi_xx fsample=fsample ix=ix
save out
saveOptions options save=selected
« Last Edit: May 17th, 2019, 9:13am by cheap_salary »
cheap_salary
Reply #4 - May 17th, 2019, 6:10am
Spectre Result.
Reply #5 - May 21st, 2019, 5:09am
Have you tried these using the native dependent source? Something like
z1 (3 0 1 0) zvcvs numer=[1 -3 3 -1] denom=[1]
Is there a problem with the z-transform implementation, or only with the translation of the Verilog-A to native?
Years ago, I was looking into the Laplace transform implementations, and I seem to recall it was easy to convert ZP to ND, but not vice-versa. Or was it that, if you have complex poles, it's hard to verify that you have the conjugate pairs in floating-point math?
cheap_salary
Reply #6 - May 21st, 2019, 5:19am
Geoffrey_Coram wrote on May 21st, 2019, 5:09am:
See https://designers-guide.org/forum/YaBB.pl?num=1557999612/0#0
It can not be, since Spectre can not give accurate result even for first order.
Reply #7 - May 21st, 2019, 5:27am
Sorry, I just re-read the original post:
But out1 was the zvcvs using numer and denom; what about using zvcvs with zeros and poles?
Reply #8 - May 21st, 2019, 6:57pm
cheap_salary
Reply #9 - May 22nd, 2019, 4:08am
Geoffrey_Coram wrote on May 21st, 2019, 5:27am:
Both can give correct result.
So we can trust Spectre Primitive, zvcvs.
However a frequency characteristics of zi_xx() is very suspicious in Verilog-A of Cadence Spectre.
https://designers-guide.org/forum/YaBB.pl?num=1298380482
H(z) = (1 -1*z^-1) / (1 +1*z^-1 +0.5*z^-2)
zeros = {0, 1}
poles = {-0.5+j*0.5, -0.5-j*0.5}
"test_zvcvs.scs" Code:
global 0
parameters fsample=10M
E1 (out1 0 in 0) zvcvs ts=1/fsample gain=1.0 \
numer=[ 1 -1 ] denom=[ 1 1 0.5 ]
E2 (out2 0 in 0) zvcvs ts=1/fsample gain=1.0 \
sxz=none \
zeros=[ 0 0 1 0 ] poles=[ -0.5 0.5 -0.5 -0.5 ]
cheap_salary
Reply #10 - May 22nd, 2019, 4:20am
Ken Kundert wrote on May 21st, 2019, 6:57pm:
I don't use zi_xx() for time domain application, since it is not valuable at all for actual operation.
https://designers-guide.org/forum/YaBB.pl?num=1361756819/3#3
zi_xx() has value only for AC-Analysis, since we have no option for periodic frequency characteristics except for zi_xx().
Reply #11 - May 22nd, 2019, 6:23pm
Before you decide that the simulator is broken, you should actually verify that you are using the function properly.  You are not seeing the nulls at multiples of the clock frequency, that suggests there is some feedthrough. Where is it coming from?  Looking at the results in the time domain might given you some understanding of what is going wrong.
Working in the frequency domain is convenient, but it can hide many issues. When things go wrong, it is generally a good idea to take a look at the time domain results.
Reply #12 - May 22nd, 2019, 6:28pm
I don't understand your comment about zi_xx() not being useful in the time domain, and your reference does not seem to mention to zi_xx() filters at all.
Why would you use them in the frequency domain if their results are useless in the time domain?
Reply #13 - May 24th, 2019, 11:02am
Are these the corresponding zvcvs elements?
I5 (out5 0 in 0) zvcvs ts=1/fsample numer=[1 -3 3 -1] denom=[1]
I6 (out6 0 in 0) zvcvs ts=1/fsample zeros=[1 0  1 0  1 0] poles=[0 0]
I7 (out7 0 in 0) zvcvs ts=1/fsample zeros=[1 0  1 0  1 0] denom=[1]
I8 (out8 0 in 0) zvcvs ts=1/fsample numer=[1 -3 3 -1] poles=[0 0]
I must be doing something wrong, because the simulator fails to converge when I6 is in, and the ac waveforms for I7 and I8 are flat 1.0 (0dB).
Reply #14 - May 24th, 2019, 11:03am
I tried a time-domain simulation with a sine source, and the waveforms all looked the same.
(When I compared those waveforms to the zvcvs I5, the latter had sharper transitions.)
