Apr 26th, 2024, 8:42pm
phase.vams (Read 1299 times)
as_rf
phase.vams
Feb 24th, 2020, 11:33am
I have problem compiling the code which is written in Ken Kundert
`include "/home/asarrafi/phase.vams" // from Listing 2, includes disciplines.vams.
module osc_phase_va(out);
output out;
phase out;
parameter real n = 0 from [0:inf); // white output phase noise at 1 Hz (rad2/Hz)
parameter real fc = 0 from [0:inf); // flicker noise corner frequency (Hz)
analog begin
Theta(out) <+ flicker_noise(n, 2, "wpn")+flicker_noise(n*fc, 3, "fpn");
I wrote the listing code and put it in phase.vmas
but cadence does not compile it for some reason and it does not show specific error. Sad
Re: phase.vams
Reply #1 - Feb 24th, 2020, 8:24pm
`include "phase.vams" // from Listing 2, includes disciplines.vams.
output out;
phase out;
analog begin
    Theta(out) <+ flicker_noise(n, 2, "wpn");
    Theta(out) <+ flicker_noise(n*fc, 3, "fpn");
You might try splitting the contribution statement into two. Cadence has become quite persnickety about the small-signal stimulus functions.
Re: phase.vams
Reply #2 - Feb 29th, 2020, 4:20am
The original code compiles OK for me, although I didn't know what was in the phase.vams code that was being included (it referred to Listing 2 - not sure which Listing 2 it's talking about; it's not Listing 2 from The Designer's Guide to Verilog AMS). So I simply changed "phase out" to "rotational out" and changed the `include to the more standard `include "disciplines.vams"
This was with SPECTRE 18.1.0.556.isr13 and 19.1.0.237.isr3 (the latest hot fixes of the current and previous release of spectre).
Which version of Spectre are you using? What is in the included file?
It should not be necessary to split up the contributions as Ken suggested; there have certainly been bugs when that was a workaround, but in this case it's either a resolved bug (if that was the problem) or something else. Knowing the version numbers used and the complete code would help with figuring that out...
Re: phase.vams
Reply #3 - Mar 1st, 2020, 2:31am
I just realised that Listing 2 is from https://designers-guide.org/analysis/PLLnoise+jitter.pdf - with the definition there, the code also compiles with Spectre 18.1 and 19.1 (unsurprisingly since the discipline is essentially similar to the standard rotational).
