seriuswhite
Hi, I am making a DFC which takes a reference clock (fref) 10GHz and generates output clock of frequency = (m/2^N)fref, where m is the digital code, and N is the resolution of the DFC. N = 10 in my case so the minimum output frequency = fref/1024. I have both digital and analog blocks in my design. The digital block generates fractional output frequency but contains a lot of spurs. The analog block is used to reduce the spurs but doesn't eliminate them completely. The digital part is implemented in Verilog, so I am using the AMS simulator.
I have the following questions:
1. How to obtain the phase noise/SFDR from the transient simulation output? Should I do post-processing of sampled transient waveform in MATLAB or can I do that in cadence itself? How to do it? Should I convert the Verilog code to VerilogA and then use pss+pnoise? Will the phase noise plot obtained from pss+pnoise also give the spurs? I wouldn't prefer to convert the Verilog code unless there's no other solution.
2. I need to get phase noise at an offset of 1KHz from the carrier. So that means I need to run the transient simulation for 1ms? Also, since I am interested in jitter of the order of 100fs, my max step in transient simulation should be <50fs. That would mean insanely large simulation time :'(. Any remedies to reduce this simulation time?
