Sep 17th, 2024, 12:03am
Delay Line (Read 1064 times)
Cascody
Allahabad
Delay Line
Feb 04th, 2021, 10:46pm
I have to delay a digital pulse by 30ns with an accuracy of ~1ps. Can this be achieved using the inverter chain delay line? If not, please suggest a topology. I couldn't find much literature on this.
I am using TSMC 65nm process.
Horror Vacui
Dresden, Germany
Re: Delay Line
Reply #1 - Jun 28th, 2021, 1:13am
What is accuracy? It seems an impossible mission in the light of process variations and local mismatches.
Though if you need a delay line with 1ps resolution, which will be calibrated to a reference, then sure it is possible. The delay can be in multiple ways even in the simplest CMOS inverter. The delay is sensitive to the supply voltage, backgate voltages of the transistors, current starving can be used, etc.
