Dec 14th, 2025, 8:14am
Cap extraction of an IC  PAD (Read 1979 times)
vlsi_design
Jun 08th, 2022, 8:36am
Hi, I want to extract the capacitance of an IC PAD. Unfortunately there are no pins and I cannot pass lvs and do extraction. I may use a metal res to  get a pin out and extract but are there better ways to do this?
Maks
San Jose
Re: Cap extraction of an IC  PAD
Reply #1 - Jun 21st, 2022, 7:12am
Yes - do LVS and extraction using layout only, without doing cross-referencing to schematic - and you can get your parasitics for your design (do not create shorts or opens, or other wrong things - in which case, the results will be meaningless).
