Paul Tuinenga
Guest
I would be delighted to e-mail the IEEE BMAS workshop version of the Cadence User Group paper. Please note that I have already found both errors in the paper.
I have not coined the term "spectral balance" which is equivalent to the more common "harmonic balance" in overall approach and results. The key differentiation seems to be whether the device models have an analytic representation in the frequency domain, e.g. the work done by P. J. Khan and M. B. Steer.
So what you see in the workshop paper is this idea expressed at a system block level -- work which definitely prepared me for what I discovered later, but please don't expect that a straight line extrapolation of what you read will lead you there. I will be happy to field questions on the paper, but not about extracting analytic, frequency domain models from SPICE code (at least not in a public forum at this time).
