May 8th, 2024, 9:08pm
SpectreRF PLL design (Read 3275 times)
Dan
Pittsburgh PA
Jan 15th, 2004, 3:08pm
I have a few general questions concerning the selection of analog simulation analyses for PLL design.  I have simulated my VCO, PFD, and Frequency divider blocks individually with transient and PSS analyses.  However, I run into problems when attempting to run a system level PSS analysis.  I assume this is due to the presence of the VCO which will produce frequencies that are non-integer multiples of the fundamental frequency.  Can PSS analysis be used to find the steady state input voltage to the VCO in a full PLL model?  Or is this value only determined through lengthy transient analyses?  I'm assuming that the phase and jitter noise of the system will be determined by performing PSS followed by Pnoise, etc. for the individual blocks and building a phase domain model based on the results (per Ken's paper).  Thanks,
Dan
Jitter Man
Am I? Or am I so
sane that u just
blew your mind?
Re: SpectreRF PLL design
Reply #1 - Jan 15th, 2004, 10:38pm
Ken addresses this topic in his paper. See section 1.2 - Direct Simulation. Basically, you can simulate the whole PLL with PSS if the PFD/CP does not have a deadzone and if the divide ratio is not too great. You just have to set tstab large enough so that it takes you to lock.
Jitter Man
