Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
May 21
st
, 2024, 12:09am
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› Current source
Previous topic
Next topic
Current source (Read 838 times)
vivekrc
Current source
Sep 14
th
, 2004, 7:21pm
How could I design a current source using the 0.13 micron technologhy libraries which can give me a constant DC current of 1m A?
I tried the current mirror......any suggestions?
Waiting on ur replies
- Vivek
IP Logged
kokabanga
Re: Current source
Reply #1 -
Sep 15
th
, 2004, 10:23am
what is the exact problem?
are you not having a scalable library or what?
what is exact problem?
anyways since u seem to need a current source...I wonder if u need a high enuf o/p resistance too...in that case anyway u may need to use a wide swing type current mirror anyways....anyways let see ...do reply man
naren
IP Logged
Vivek Chandrasekhar
Guest
Re: Current source
Reply #2 -
Sep 15
th
, 2004, 1:22pm
The problem I am having is to generate a current source...using current mirror which can give me a output current of 1 mA. Also I need a high o/p resistance.
what is a wide swing current mirror?
Also I need to know which analysis do I need to use to find the exact current.
I need to use this current source in a current mode sample and hold circuit....which I have to fianlly put on layout.
Would really apprecaite if u could suggest me a way to get thro ....
- Vivek
IP Logged
kokabanga
Re: Current source
Reply #3 -
Sep 15
th
, 2004, 1:24pm
please use chapter 4 from
analysis and design of analog ICs by gray,meyer,hurst,lewis
it is not easy to explain here
rather impossible
naren
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
